Issue VF-1507
The Content Engine now supports a new kind of field called a collection field. Collection fields provide a simple means of integrating content published via Atom feeds into your content items. You can therefore use collection fields:
To integrate external Atom-published content (from a public feed such as a stock ticker, for example)
To integrate internal data by publishing it as an Atom feed that you can then access from Content Studio via a collection field.
To access information about your publications from Content Studio - possible since the Content Engine's own web service is based on Atom feeds. The Content Engine now includes a special section feed aimed at this kind of use. This feed contains entries for all the sections to which the current user has access and you can use it to include a "section picker" field in your content types.
A collection field is defined in the usual way in the content-type resource. The definition includes
the URL of the Atom feed from which content is to be integrated, plus
a specification of the precise data to be selected from the selected
entry.
Collection fields are displayed as "search as you type" text fields in Content Studio. When the user starts to type in the field, a list of Atom entry titles that match the entered text are displayed below the field. When the user selects one of the listed entries, a value is extracted from it and stored as the collection field's value.
For a full description of collection fields and how to use them, see http://documentation.vizrt.com/ece-advanced-temp-dev-guide/5.5/collection_fields.html.
Improved integration possibilities
Content Studio
Low
Issue VF-4401
It is now possible to group a set of fields together using the
ui:field-set in the content-type resource. Fields that are grouped
in this way are enclosed in a box when displayed Content Studio. For
further information, see http://documentation.vizrt.com/ece-resource-ref/5.5/ih_field_set.html.
Improved user interface.
Content Engine, Content Studio
Medium
Issue VF-4376
You can now create and edit sections using Content Studio - it is no longer necessary to use Web Studio for these purposes. For details, see http://documentation.vizrt.com/ece-content-studio-guide/5.5/using_a_section_editor.html. However, you still need to use Web Studio to move and delete sections.
It is now also possible to get, create and update sections via the Content Engine's web service. For details, see http://documentation.vizrt.com/ece-integration-guide/5.5/retrieve_a_section.html and the following few topics in the Escenic Content Engine Integration Guide.
Improved usability
Content Engine, Content Studio, web service
High
If the name, directory name or the URI of a section is changed, all the content items in that section are re-indexed.
Issue VF-4183
The relationship between binary content items and the binary objects and metadata they reference has been moved to the database. This makes it possible for the system to determine which binary objects are no longer in use and delete them from the file system.
Improved use of storage
Content Engine
Medium
This change may cause a small increase in the number of database queries generated by the Content Engine. It will, however, also reduce the number of file accesses on the binary folder.
To build an index of all the used binary objects, the upgrade services need to be enabled. Follow the instructions below for at least one engine host to do so.
Add
service.8.00-article-upgrade-service=/com/escenic/upgrade/ArticleUpgradeService
to Initial.properties.
Set
serviceEnabled=true
in /com/escenic/upgrade/ArticleUpgradeService.properties
and /com/escenic/upgrade/FiveFiveStorageUpgradeService.properties
If you are upgrading from 5.2 and want to migrate tags then you will also need to set
serviceEnabled=true
in /com/escenic/upgrade/FiveFiveStorageUpgradeService.properties.
This component also requires some additional steps - see the upgrade
instructions in the release notes for version 5.3.0.2 for details.
Restart the engine host. Once the host has
restarted, the upgrade service will start upgrading binary content
items from 5.4 to 5.5. You can monitor the progress of the upgrade
service at http://myserver/escenic-admin/browser/Global/com/escenic/upgrade/ArticleUpgradeService?property=state.
This service will run on only one of the currently upgraded hosts. If
the host running the service goes down, the service will start
automatically on another host.
Nothing will be removed from the file system at this point. Both binary content items created on 5.4 and binary content items created on 5.5 will work on all engines.
http://localhost:8080/escenic-admin/browser/Global/com/escenic/upgrade/ArticleUpgradeService?property=serviceMessage
will now display the message "All articles are upgraded. This service
can be disabled ". You should then remove the service from Initial.properties.
You can now remove the any garbage from the binary folder. Visit http://myserver/escenic-admin/browser/Global/com/escenic/upgrade/FiveFiveStorageUpgradeService.
By default this service simply deletes the unused files. You can,
however, force it to create a backup by setting its backupFolder property (to /tmp/binary/backup/, for example). If this
property is set, the garbage files are moved to the specified folder
rather than being deleted. The folder structure is preserved in this
backup copy, so you can just copy the files back into the storage
folder if necessary.
To start the clean-up process, Invoke the method called removeUnusedFilesFromStorage. The method may
take some time to complete if your storage folder is large. It will
also use some memory, so it should not be run on a host that is under
high load.
When this method has completed, all the garbage files will have been removed from your storage folder.
Issue VF-4380
The search results panel in Content Studio has a new, improved look and feel. The new layout is more compact and better organized.
In particular, the detail view now clearly distinguishes image content items from other content items, so that the user does not need to switch between detail and thumbnail views. It is now also possible to sort search results by different fields in both ascending and descending orders.
These changes are also reflected in other Content Studio list panels such as inboxes, lists and so on.
Improved usability
Content Studio
Low
Replace the old "solr_atom.xsl" in your solr configuration
directory with the new one which can be found in the solr/conf/xslt folder of the distribution.
Replace the old "schema.xml" in your solr configuration directory with the new one which can be found in the directory "{engine-distribution}/solr/conf/". For sorting by title to work on old content items a re-index is required.
Issue VF-4442
The Content Studio list editor now displays content item summaries and thumbnail images.
Improved usability
Low
Issue VF-4434
The use of the allow-content-types
element in the layout-group resource
gives publication designers detailed control over the placing of
content items on section pages - they can use it to specify that only
certain content types may be added to certain areas of the page.
Support for this functionality has been improved in two ways:
Publication designers no longer need to individually specify
each disallowed content type for each area/group from which they
are to be excluded. It is now possible to define groups of content
types in the layout-group resource
and then exclude whole groups using a new ref-content-type-group element. For
details, see http://documentation.vizrt.com/ece-resource-ref/5.5/lg_allow_content_types.html.
Previously, Content Studio allowed users to actually drop content items onto areas where they were disallowed. The disallowed items were then removed when the section page was saved. Now, user are prevented from dropping the disallowed content items in the first place.
Improved usability.
Low
Issue VF-4422
Some new configuration options have been added for indexer webapp:
The following can be set in the Tomcat's context.xml file:
escenic/index-producer-connection-timeout
(Connection timeout in milliseconds for the connection to the
indexer web service, default value: 4000)
escenic/index-producer-socket-timeout
(Socket timeout in milliseconds for the connection to the indexer
escenic/index-consumer-connection-timeout
(Connection timeout in milliseconds for the connection to Solr,
escenic/index-consumer-socket-timeout
(Socket timeout in milliseconds for the connection to Solr,
The maximum time to wait for a binary file to finish indexing can
be set using the maxWaitTime property in
the com/escenic/search/index/BinaryIndexerPlugin.properties
configuration file. Default value: 3000 (milliseconds).
In addition, the maxFileSize property
in the com/escenic/search/index/BinaryIndexerPlugin.properties
configuration file now has a default setting of 20 MB.
For more information about these settings, see http://documentation.vizrt.com/ece-server-admin-guide/5.5/Setting_Timeouts_and_Limits.html.
Improved configuration options
Content Engine, indexer
Low
Issue VF-4345
The SolrDelegatingSearchEngine
component has a field of type org.apache.commons.httpcllent.HttpClient which
is used for all communication with Solr. This HttpClient object can
now be configured in the usual way by adding a properties file to a
configuration layer.
Improved configurability.
configuration, search
Low
Open com/escenic/webservice/search/DelegatingSearchEngine.properties from one of your configuration layers (if present) in a text editor. If this file contains
soTimeout=<some_value>
or
connectionTimeout=<some_value>
These two settings must be moved to
com/escenic/webservice/search/HttpConnectionParams.properties
Issue VF-4336
The color of the field labels in Content Studio has been changed to improve contrast and legibility. The color of the character count text has also been modified (made slightly lighter).
Improved usability.
Content Studio
Low
Issue VF-4310
The Content Engine's web service now includes a change log for tags. A Tag structure feed now contains a link to its change log. The change log contains records of all changes made to the tags in the structure, and can be used in the same way as other web service change logs.
Improved 3rd-party integration.
indexer
High
In order to populate the tag structure change logs, tags must be
reindexed. To do this you need to invoke the /com/escenic/search/index/Indexer component's
reIndexTag method. You can do this from
the escenic-admin web application's
component browser.
Issue VF-4306
Previous versions of Content Studio, however, allowed users to drop
Content Studio now prevents users from dropping the disallowed content items in the first place rather than removing later.
Improved usability
Content Studio
Low
Issue VF-4238
A number of Java beans, bean methods and JSP tags have been removed from the Content Engine's presentation layer. The removed beans, methods and tags have been deprecated for several releases.
Removed Java beans
neo.xredsys.presentation.PresentationRelationImage
neo.xredsys.presentation.PresentationRelationImageAdapter
neo.xredsys.presentation.PresentationRelationImageHelper
neo.xredsys.presentation.PresentationRelationLink
neo.xredsys.presentation.PresentationRelationMedia
Removed bean methods
neo.xredsys.presentation.PresentationElement.getLegacyContent()
neo.xredsys.presentation.PresentationArticle.getLayoutId()
neo.xredsys.presentation.PresentationArticle.getPrinted()
neo.xredsys.presentation.PresentationArticle.getAllRelatedObjects()
neo.xredsys.presentation.PresentationArticle.getAllRelatedObjectsCount()
neo.xredsys.presentation.PresentationPool.getPoolId()
neo.xredsys.presentation.PresentationPool.getPoolTypeName()
neo.xredsys.presentation.PresentationPool.getRuleTypeName()
neo.xredsys.presentation.PresentationPool.getFrontpageLayout()
neo.xredsys.presentation.PresentationPool.getArticle(int
pId)
neo.xredsys.presentation.PresentationPool.getPoolElements(String
pElementGroupName)
neo.xredsys.presentation.PresentationPool.getPoolElement(String
pElementname)
neo.xredsys.presentation.PresentationPool.hasElements(String
pColumnName)
neo.xredsys.presentation.PresentationPool.getElementGroupNames()
neo.xredsys.presentation.PresentationPool.getElements()
Removed JSP tag libraries
escenic-relation
Removed JSP tags
template:hasElement
template:hasNoElement
template:insert
template:defaultPresentationArticle
template:defaultPresentationPool
template:defaultPublication
template:defaultSection
article:author
article:authors
article:field
article:type
article:hasNoRelation
article:hasrelation
article:hasNoValue
article:hasValue
article:homeSection
article:isType
article:lastChanged
article:link
article:publishedDate
article:sections
article:latestArticles
article:relatedArticles
profile:field
profile:hasValue
profile:hasNoValue
section:hasAgreement
section:lastChanged
section:link
section:name
section:parameter
section:validateAgreement
util:case
util:dateFormatter
util:equal
util:evaluate
util:isEmpty
util:isNotEmpty
util:notEqual
util:switch
util:valueOf
Simpler API and documentation
presentation layer, taglib
Medium
Any templates or Java code you have that still use the removed tags and beans must be rewritten. For guidance on how to do this, see http://documentation.vizrt.com/ece-tech-notes/5.5/how_to_upgrade_templates_to_5_5.html.
Issue VF-4231
The escenic-admin web application now
includes an option for generating a full thread dump of the Content
Engine.
Better diagnostics.
escenic-admin
Low
Issue VF-4211
The Content Engine web service's handling of person records has been improved so that all person information stored in the Content Engine can now be represented in a web service person feed. The following improvements have been made:
The entry now includes a summary
element that contains the person's full name.
The entry's title element now
contains the person's surname rather than the full name.
The entry now includes a link
element that offers a link to the person's "owning"
publication.
The entry's VDF payload document now contains a description field.
It is no longer possible to create a person entry without a surname.
The web service is now capable of handling all user information stored by the Content Engine.
High
Issue VF-4196
Content Studio incorporates a number of background processes that refresh content item editors in response to events. In previous versions, the management of these processes was relatively complex and error prone. This background process management has now been simplified and improved.
Improved stability
Content Studio
Medium
The following systems properties that were used to control the delay interval for the tasks are no longer in use:
com.escenic.studio.core.editors.AbstractContentEditor.refreshInterval
com.escenic.studio.core.editors.AbstractContentEditor.refreshLockInterval
com.escenic.studio.core.editors.ContentSummaryListPropertyEditorUI.refreshInterval
com.escenic.studio.core.editors.IndexPagePropertyEditor.refreshInterval
com.escenic.studio.core.editors.IndexPagePropertyEditor.refreshListInterval
com.escenic.studio.core.editors.ListContentEditor.refreshInterval
These system properties are now replaced by the following system properties (all values are milliseconds):
com.escenic.studio.editors.ContentEditor.refreshContentInterval
controls how often a content editor checks for an updated item.
The default value is 5000 and the minimum value is 1000.
com.escenic.studio.editors.ContentEditor.refreshLockInterval
controls how often a content editor checks for updated locking
information. The default value is 1000 and the minimum value is
500.
com.escenic.studio.editors.ContentEditor.refreshRelatedContentInterval
controls how often an article's related items or a section page's
teasers are refreshed. The default value is 10000 and the minimum
value is 2000.
If you are using any of the old system properties, please use the new system properties.
Issue VF-3857
The database resource lock cleanup service (which deletes old unused resource locks) is now enabled by default.
Improved usability
Content Engine
Low
Issue VF-3707
The Content Studio "steal lock" function now always works, even for full content item locks obtained via the Java API.
Improved usability
web service
Low
Issue VF-4432
The sliders in the Content Studio image editor can now be controlled using the left and right arrow keys.
Improved usability
Content Studio
Low
Issue VF-4428
The related content panel in the Content Studio, content editor now automatically expands when a content item is dragged over it, thus simplifying drag and drop of related content items.
Improved usability
Content Studio
Low
Issue VF-3799
In previous versions of Content Studio, the shortcuts for the options in the View menu were Ctrl or "Cmd" + a function key. These key combinations did not always work and have therefore been replaced by Ctrl or "Cmd" + number key combinations.
Improved usability
Content Studio
Low
Issue VF-4488
Previous versions of the Content Engine had a number of limitations regarding the names of binary objects and how they were accessed in the presentation layer:
A binary object would not be displayed in the presentation layer if its title contained a slash (/) character.
Attempts to access a binary object would fail in some
circumstances if its name contained a URL-decoded character.
Requests for image().jpg, for
example, would fail (but requests for image%28%29.jpg would succeed).
Attempts to access an alternate image would fail unless the
/alternates/ component of the URI was
all upper case (/ALTERNATES/).
All of these problems have now been fixed.
Improved reliability
engine-presentation
Medium
The URLs of binary objects will now use '%20' instead of '+' to encode spaces and '?', '/' and '%' characters will be replaced with '-' characters.
Issue VF-4473
In previous versions, the Content Studio browser component (used in browser research panels and the geocode plugin) would not work in a 32 bit Java runtime environment. This problem has now been fixed by upgrading the browser component (JXBrowser) to the latest version.
Improved platform support
Content Studio
Low
Issue VF-4457
A potential deadlock in Content Studio is now fixed.
Improved reliability.
Content Studio
Low
Issue VF-4305
In previous versions of the Content Engine, the order of the values selected from a multiple selection enumeration field was not preserved when a content item was saved in Content Studio. This problem has now been fixed and the order of the selected values is now preserved.
Correct behavior
Content Studio
Low
Issue VF-3763
In previous versions, the search index was not updated after a content item was moved from one section to another section using Web Studio's Move content option. This problem has now been fixed.
Correct search results.
Content Engine
Low
Issue VF-4465
Since version 5.3 of the Content Engine, the API method User.getSections has returned all sections the
user has access to, regardless of type. The method has now been
reverted to its pre-5.3 behavior: sections of type community are not returned. This will improve
performance if there are many sections of type community.
Note that User.getSections is in fact
a deprecated method. There is a new utility method resolveUserSectionsForPublication that you can
use instead.
Improved performance
api
Medium
Issue VF-4388
In previous versions of the Content Engine, attempts to access the author of a cross-published content item could sometimes fail if the author did not belong to the same publication as the content item. This issue has now been fixed.
presentation layer
Low
Issue VF-1316
In previous versions of Content Studio, the clipboard did not always display content items correctly. The following items were sometimes missing from the listed entries:
State icon
Summary text
Thumbnail image
The problem has now been fixed. All the above items are now included in clipboard entries.
Improved usability
Content Studio
Low
Issue VF-4475
In previous versions of the Content Engine, the upgrade service was unable to migrate legacy tags with titles containing "&" characters. This problem has now been fixed.
Migration now updates tags like "bob & alice" properly which have "&"
migrator
Low
Issue VF-3541
Previous versions of Content Studio would not start in some cases on machines where Java 7 was installed as the default Java runtime environment. This problem has now been fixed so that Java 6 is used when necessary, even if Java 7 is the default JRE.
Improved deployment
Content Engine
Low
Issue VF-4490
Previous versions of Content Studio would sometimes insert unwanted paragraph (p) tags into imported XHTML content. This problem has now been fixed.
Improved usability
Content Studio
Low
Issue VF-4489
In previous versions of the Content Engine, deleting a publication
would sometimes fail with an SQLException. This only happened if users from
another publication had been given access to the publication you were
trying to delete. This problem has now been fixed.
engine
Low
Issue VF-4486
In previous versions of the Content Engine, deleting a section would fail if:
The section did not inherit access rights from its parent section
The section was the home section of one or more content items
engine-core
Low
Issue VF-4470
Some information about the the default Solr stemming settings and how to either disable or change them for use with non-English content has been added to the Installation Guide: http://documentation.vizrt.com/ece-install-guide/5.5/search_engine_configuration.html
improved documentation.
documentation
Low
Issue VF-4411
In previous versions, the indexer webapp did not close the error document after writing to it. If the indexer encountered a large number of failures while indexing documents, this would eventually cause the indexer itself to fail with the error Too many open files. This problem has now been fixed.
Improved stability
indexer
Low
Issue VF-4405
In earlier versions of the Content Engine, adding a
section-specific role (reader, administrator, useradmin, editor or
journalist) to a user or user group via XML import would result in a
PersistentStoreException if the user or
user group already had the role. This problem has now been fixed.
Content Engine
Low
None
Issue VF-4392
In previous versions of the Content Engine, importing a content item that contained an in-line relation to a cross-published content item would not work correctly: the in-line relation would never get resolved. This problem has now been fixed. If the cross-published content item is already imported, then the in-line relation is resolved immediately. Otherwise it is resolved whenever the cross-published item is imported.
Correct behavior
syndication
Low
Issue VF-4386
In previous versions of Content Studio, the custom styling
drop-downs created using ui-style-class
elements in the content-type resource did
not work correctly:
There were problems with the display of certain fonts (specifically, Webdings and Wingdings)
The drop-downs did not correctly display the style of the currently selected text
These problems have now been fixed.
These problems are fixed now.
improved usability
Content_Studio
Low
Issue VF-4340
VDF model documents generated by the previous version of the Content Engine's web service failed to include definitions of date fields appearing inside complex or array fields. This problem has now been fixed.
Improved integration interface.
web service
Low
Issue VF-4328
In previous versions of the Content Engine, no error was logged if the indexer web app failed to post an index document to Solr. This problem has now been fixed: if an index document cannot be posted to Solr then an error is logged. Moreover, if more than 100 such errors occur within one minute, then the indexer is paused. It can be resumed from the indexer web app's administration interface once the reason for the errors has been corrected.
Better reporting of search indexing problems.
indexer
Low
Issue VF-4296
In previous versions of Content Studio, when a user started to edit the inherited content in a rich text field, the keyboard caret was incorrectly positioned. This problem has now been fixed.
Correct behaviour
Content Studio
Low
Issue VF-4289
In version 5.4.0 of Content Studio, using the Javascript API to display a notification would cause the mouse pointer to stop responding to context changes: it would no longer change shape in response to the capabilities of the underlying user interface components. This problem has now been fixed. The pointer now changes shape as expected even after Javascript notifications have been displayed.
Improved usability
Content Studio
Low
Issue VF-4281
In previous versions of the Content Engine, attempts to import a
content item with an unresolved relation would fail if either the
source or sourceid attribute contained more than one hash
(#) character. This problem has now been fixed.
engine-core, syndication, web-service
Low
Issue VF-4278
On sites where memcached is used, it is now possible to configure the Content Engine so that flushing the cache also flushes the memcached caches. For further information, see http://documentation.vizrt.com/ece-install-guide/5.5/configure_presentationarticlecache_instances.html
Possible to flush the memcached cache.
Content Engine
Low
If this functionality is enabled, flushing the cache on one host will affect the performance of all hosts in a cluster until the cache is populated again.
Issue VF-4271
Previous versions of Web Studio could sometimes delete the global role settings of an edited user group. This only happened if you displayed the user group editor's Tag Structures form before saving your changes. The problem has now been fixed.
webstudio
Low
Issue VF-4270
Since version 5.3.2.2 of the Content Engine, original image versions have been displayed with reduced quality. This problem has now been fixed, and original image versions are displayed in their original quality.
Correct behavior
presentation layer
Low
Issue VF-4190
The Content Engine update service should be called immediately after a content editor is opened in Content Studio. Previously this was possible only for text/xhtml/enumeration fields.
The update service is now called immediately for all types of field, ensuring that the user only sees the intended field content.
Improved user experience
Content Studio
Low
Issue VF-4167
In previous versions, it was not always possible to delete a user from Web Studio: sometimes the operation would fail due to the existence of authorization tokens owned by the user. This problem has now been fixed: any authorization tokens owned by the user are deleted together with the user.
improved reliability.
engine-core
Low
Issue VF-4143
In previous versions, updating a content item could cause a ConcurrentModificationException to occur. The
exception only occurred when updating content items that contained
fields with underscore characters in their names. This problem has now
been fixed.
presentation layer
Low
Issue VF-4129
In previous versions of Content Studio, when users inserted links or images into rich text fields, they were not required to specify a URI in the Address field of the displayed dialog. However, if no URI was specified in the field, then an error would occur when the user attempted to save the content item. This problem has now been fixed by making the "Address" field mandatory: it is not possible to click OK if the field is empty.
Improved usability.
Low
Issue VF-4116
The logging library used by the Content Engine, log4j has a known performance issue when
running in a multi-CPU / multi-kernel environment. All calls to Logger.getLogger end up in the same
synchronized block, so if this method is invoked by multiple threads,
all of the threads except one have to wait for a monitor.
This issue has now been fixed by adding a cache around log4j.
Note that this fix will not work unless the Content Engine that
initializes log4j itself. This is
normally the case: the Content Engine initializes log4j unless it has been explicitly prevented
from soing so by setting the system property com.escenic.log4j.noinit.
improved performance
logging
Low
Issue VF-4037
In previous versions of the Content Engine, attempts to load an unsupported type of image would result in a null pointer exception. This situation is now handled more correctly: the Content Engine now reports an internal server error writes the URI of the offending image to the log.
Content Engine
Low
Issue VF-4541
In previous versions, the distribution of local events could
sometimes fail with an AccessControlException, preventing caches from
being properly updated and causing event listeners to fail. Once the
distribution of events started to fail, it would continue failing
until the server was restarted.
engine-core
Low
Issue VF-4527
In previous versions of Content Studio, it was not possible to edit a section page after deleting one of the page's lists. This problem has now been fixed.
Correct behavior.
Low
Issue VF-4431
In previous versions of Content Studio, the section icon was not always displayed beside the section name in the Content Studio section page editor. The problem has now been fixed.
Correct behavior
Content Studio
Low
Issue VF-4318
In previous versions of Content Studio adding a section to a new content item was difficult because the drop zone for sections was very small. This problem has now been fixed by increasing the size of the section drop zone.
Improved usability
Content Studio
Low
Issue VF-4216
In previous version, PresentationElemenentDecorator#getContent would
fail when attempting to decorate PresentationPool elements. This problem has now
been fixed.
Improved API functionality.
presentation layer
Low
Issue VF-4198
In previous versions of the Content Engine you could not delete a user group from Web Studio if the user group had any roles assigned to it. This problem has now been fixed, so you can delete a user group whether or not it has any roles.
Correct behavior
Content Engine
Low
None.
Issue VF-4180
In previous versions of the Content Engine, the escenic-admin component browser did not support
properties of type java.io.File, java.net.URL, java.net.URI or collections. This issue has now
been fixed so that all configuration layer properties can modified at
run time using the component browser.
All property types can be modified using the component browser
escenic-admin, nursery
Low
Issue VF-4038
Previous versions of the Content Engine incorrectly returned "500 Internal Server Error" in response to a web service request if the URI contained an invalid section ID. This problem has now been fixed and the Content Engine a correct "400 bad request" response.
Correct behavior
Content Engine, web-service
Low
None.
Issue VF-4016
Previous versions of Content Studio could fail when creating a cache directory during login. This problem has now been fixed.
Content Studio
Low
Issue VF-3606
At some installations, the presentation servers are denied write
access to the multimedia directory, for security reasons. In previous
versions of the Content Engine, this kind of configuration caused an
exception every time an image version that did not already exist was
requested. To prevent this happening, you can now configure the FilterCache to display a dynamic image version
even if the file cannot be cached.
Repeatedly generating images on the fly without writing them to the multimedia folder will result in a higher load on the presentation servers. You can prevent this becoming a problem by:
Making sure your editorial work-flow involves viewing or previewing all article and section pages that use a new or modified image. This will ensure that new image versions get written to the multimedia folder by editorial servers (which do have write access) and without affecting site performance.
Making sure there is a web-cache in front of the presentation layer that is configured to serve images. This ensures that on the occasions when an image version is not created by the editorial servers, no incident occurs. When this happens, an error is written to the log as a warning that you may have a performance problem. You can then remedy the situation by accessing the image version on an editorial server, which will ensure it is added to the multimedia folder.
This feature is optional and is not enabled by default.
To activate this feature, you must add the following parameter to
the CacheFilter configuration in your
web.xml file:
<!-- Cache Filter Configuration -->
<filter>
<filter-name>cache</filter-name>
<filter-class>com.escenic.presentation.servlet.multimedia.CacheFilter</filter-class>
<!-- Enable read-only access to the multimedia directory: -->
<init-param>
<param-name>allowNonCachedUrls</param-name> <param-value>true</param-value>
</init-param>
</filter>
Improved security
presentation layer
Low
Issue VF-3448
In the previous version of Content Studio, changing from a wired network to a WiFi network that requires use of a proxy server would cause browser research panels to fail. This problem has now been fixed. The browser panels now detect the change and reconfigure themselves accordingly.
Content Studio
Low
Issue VF-4339
In previous versions of the Content Studio, unset expiry dates would sometimes be displayed as set to a date a long time in the future. This problem has now been fixed.
Correct behavior
Content Engine
Medium
None.
Issue VF-4224
In previous versions of the Content Engine, any attempt tp set a complex field via the web service would clear the field value. This problem has now been fixed.
The webservice now works as expected for complex fields.
webservice
Medium
The field names are no longer case insensitive in the content document.
Issue VF-4022
In previous versions, Content Studio could fail when saving its internal HTTP cache to disk. This problem has now been fixed.
Content Studio
Low
Issue VF-4002
In previous versions of the Content Engine default values were not assigned to empty content item summary fields even if they were defined as required fields. This problem has now been fixed, and empty summary fields are handled in the same way as other empty fields: if it is defined as a required field and a default value is available, then the default value is assigned to the field.
Improved consistency.
Content Engine
Low
Issue VF-3840
In previous versions of the Content Engine, unchecking the Inherit access control option on the Web Studio
section editing page could sometimes cause an SQLException. This only occurred if one or more
content items had this section or one of its children as home section.
Correct behavior
core
Medium
Issue VF-3805
The previous version of Content Studio would report that it was connected to an unknown server if the web service URL was specified as a relative URL. This problem has now been fixed.
Improved usability
studio
Low
You can upgrade to release 5.5.0.131544 from release 5.4.0.123767 or later. The basic procedure for upgrading is outlined below. For a multiple-host installation, however you should read Rolling Upgrades, below. This describes how to upgrade your installation incrementally, one engine host at a time.
Download the 5.5.0.131544 distribution to your assembly host and extract it from the ZIP file.
Download the latest version of the assembly tool and extract it from the ZIP file.
Either:
Edit your assembly tool's assemble.properties file, setting engine.root to point to the new location,
or
If engine.root points to a
symbolic link, update the symbolic link instead
Perform the upgrade tasks for Deprecated tags and beans removed from presentation layer
If you are upgrading from a release prior to 5.4.2.129274, check the Upgrade Instructions section in the Release Notes of all releases between your release and 5.4.2.129274, and carry out any "additional upgrade tasks" listed in them.
Reassemble the Content Engine using the ece script by entering the following
command:
ece assemble
Stop your application server(s).
Redeploy the EAR file to all application server(s).
release and 5.4.2.129274, and carry out any post-deployment tasks
listed in them. Typical post-deployment tasks include updating
and/or regenerating Solr indexes, running database upgrade scripts
and so on. You will find any database upgrade scripts you may need
to run in this distribution's /opt/escenic/engine/contrib/database
folder.
Run the database upgrade scripts supplied for your database. You will find the scripts in one of the following folders:
engine-5.5.0.131544/contrib/database/sql/MySQL/upgrade/to-5.5.0
engine-5.5.0.131544/contrib/database/sql/Oracle/upgrade/to-5.5.0
There are two scripts: upgrade-phase1.sql and upgrade-phase2.sql. The tasks described in
Rolling Upgrades should be performed between executing the phase 1
script and the phase 2 script.
Check the additional upgrade tasks specified for the following changes and carry out any actions that are necessary for your site:
Start your application server(s).
Check the post deployment upgrade tasks specified for the following changes and carry out any actions you think are necessary for your site:
Alternatively to upgrading the whole cluster at once, it is also possible to upgrade one host at a time. To carry out a rolling upgrade from 5.4 to 5.5:
Perform upgrade steps 1-6.
Run upgrade-phase1.sql.
Perform upgrade steps 7-9 and 11-12 on one engine host at time. Start with the presentation host(s) and end with the editorial host(s).
upgrade-phase2.sql.
Perform upgrade step 13.
