Supported NLE Systems
NLE Plugin | Available Editors | Plugin Version | Metagraphics Support | Stop Point Editing |
Graphics Plugin for Avid | Viz Pilot, Viz Pilot Edge, Viz Trio (Win), Graphics Plugin Editor (Mac - not supported on macOS Catalina and newer versions.) | 2.4.0 | Mac - No Win -Export to Viz One only Requires Avid Assistant 1.16.1 Trio does not support metagraphics. | Yes |
Graphics Plugin for Adobe | Viz Pilot, Viz Pilot Edge, Viz Trio (Win), Graphics Plugin Editor (Mac - not supported on macOS Catalina and newer versions.) | 2.4.0 | Yes. Win and Mac full support. Export to / import from Viz One. Import requires Adobe Assistant 3.2. Trio does not support metagraphics. | Yes |
Graphics Plugin for Edius 8 and 9 | Viz Pilot, Viz Pilot Edge, Viz Trio | 2.3.1 | No | No |
Graphics Plugin for Edius X | Viz Pilot, Viz Pilot Edge, Viz Trio | 2.5.0 | No | No |
