Script Runner, Crop Service and Pilot Data Server services logs to different files.
Service | Log file path | Configurable |
Pilot Data Server | %ProgramData%\Vizrt\Logs\PilotDataServer\server.log | Log file size and log level can be configured in the Launcher UI. The configuration is written to PilotDataServerHostService.exe.config in the installation path. |
Crop Service | %ProgramData%\Vizrt\Logs\CropService\cropservice.log | Log file size and log level can be configured in PilotCropServiceHost.exe.config in the installation path. |
Script Runner | %ProgramData%\Vizrt\Logs\ScriptRunner\scriptrunner.log | Log file size and log level can be configured in PilotScriptRunnerHostService.exe.config in the installation path. |
Thumbnail Generator | %ProgramData%\Vizrt\Logs\Viz Pilot Thumbnail Generator | Log file size and log level can be configured in PilotThumbnailGeneratorHostService.exe.config in the installation path. |
Note: The maximum default size of the log is 100Mb, with one active file and one .old file.
Logging Configuration
The configuration of Logging for Pilot Data Server is done using the Pilot Data Server Launcher.
On the initial window of the launcher, click the Settings
button.Select Logging Config to show the configuration settings.
Log File Size: Defines the maximum file size for log files (in mb) for PDS. When the size is exceeded, a new file is created in the same folder.
Log Level:Debug: Log message for debug purposes.
Info: Log for general messages, for example "Connected to host", etc.
Warning: Log message for irregular situations that may cause unexpected results.
Error: Used for serious and unexpected errors, that may cause situations with unwanted results.
After configuring, click Save.
Warning: Clicking Save applies changes to all settings in this window, including logging, licensing, PDS, etc.
Info: Each log level, logs all of the messages of the level below. Therefore, debug logs all of the messages while the error level only logs errors.
