Version 1.5 | Published April 05, 2022 ©
Configure the Studio
This section details how to configure Viz Virtual Studio.
images/download/attachments/85888035/image2021-8-16_14-23-50.png
  1. Click Open to select a previously saved studio configuration, or create a new configuration by clicking Save As.
  2. Set the Frequency frame rate. Available options are:
    • 50 Hz
    • 60 Hz
    • 59.94 Hz
    • 30 Hz
    • 29.97 Hz
    • 25 Hz
    • 24 Hz
  3. Set the Synchronization base:
    • Freerun: Does not synchronize. Tracking Hub runs using its own time base, corresponding with the configured frequency. This option should not be used in production environments.
    • AV-Card: Synchronizes using Plura PCL-PCI or PCL-PCIe sync cards.
    • Viz Engine: Synchronizes with a Viz Engine running on the same computer.
  4. Go to Configure Topology.
