Version 1.5 | Published April 05, 2022 ©
New in Version 1.5.0
images/download/attachments/72108579/image2021-8-27_8-47-40.png
  • A Post Data Inspector tool is now available, which is able to read and display recorded data and makes it easier to identify missing packages. Additional recorded data can be exported to PDF.
  • A Replay tool has been added, which is able to start, stop recording and watching the clip folder of Viz Engine to display information on the play time, timecode and more. Additional the tool is able to load clips into Viz Engine, start and stop the replay, enables shuttling and start recording of the channel recorder.
  • Tracking Hub supports some non Broadcast frame rates. These are: 24, 25, 30 and 29.97 Hz.
  • Studio Manager is now able to display any element of the rig structure and display all values independent. The displayed values are: Value, Offset and Value+Offset.
  • Studio Manager now enables auto logon.
  • New crane geometries are supported now.
  • The new TrackMen motion capture format is now implemented.
  • A new timecode service has been added which is able to receive post and live timecode from Viz Engine.
  • The camera service has been extended, so that now any number of rigs can be send to one Engine. This makes setups with many Engines more simple.
  • Chroma key setting can now be stored in shared memory of Viz and these settings can be triggered by Tracking Hub when switching. An additional command line was added to execute arbitrary commands on switching.
  • Loading the configuration in post/replay setups has been improved.
  • The parameter port of Studio Manager can now be configured.
  • The delay for time code based tracking data has been minimized.
  • A new lens file rig has been added, which can be used to overwrite DOF information from a tracking system.
  • The functionality or the lens file editor has been improved. A new point matrix view was introduced to simplify point selection. If no lens file was loaded in Tracking Hub, a raw file is loaded on start calibration.
  • The Eagle-eye protocol has been implemented.
  • The Sky x cam protocol is supported now.
  • The Cable-cam protocol is supported now.
  • The GeoPro protocol has been added.
