Version 1.5 | Published April 05, 2022 ©
Post Data Inspector
The post data inspector is a tool which can load recorded data, either from parameters or camera services, and display this data in a window.
images/download/attachments/85889989/image2021-7-31_15-27-18.png
After the window opens, a recorded file can be opened by selecting File > Load. A File dialog box opens and a post record session can be selected. If the recording is over several hours, loading can take quite some time. A progress bar in the status line shows the position of reading. After the file has been loaded, the Menus and Camera Channels are filled with the available parameters.
images/download/attachments/85889989/image2021-7-31_15-41-34.png
images/download/attachments/85889989/image2021-7-31_17-2-53.png
It is possible to multiple select parameters in the menus; however, the units of the parameters can be different (for example, it is not possible to compare distances (cm) with Euler angles).
images/download/attachments/85889989/image2021-7-31_17-3-58.png
This tool can also be used to make long term recordings of the incoming tracking data. If there is no timecode present or no timecode reader card built into the machine, the Tracking Hub provides SimPost and SimLive timecode.
images/download/attachments/85889989/image2021-8-26_17-4-19.png
This simulated timecode start at startup time with a value of Zero. So if you need to know the time, the error happened, not the time of the Tracking Hub startup time. Select the tracking system you want to observe and activate the record settings for the incoming parameters.
images/download/attachments/85889989/image2021-8-26_17-7-30.png
The record time is limited to 24:00 hours, but the recommended recording time should not exceed 12 hours. Otherwise, the PostDataWindow slows down.
images/download/attachments/85889989/image2021-7-31_15-46-23.png
Controlling the Data-plot
Action
Shortcut
Pan
Right mouse button,
ALT + Left mouse button,
UP/DOWN/LEFT/RIGHT ARROW keys, CTRL + ARROW keys for fine pan
Zoom
Mouse wheel,
CTRL + Mouse wheel for fine zoom
Zoom in
Mouse extra button 1,
+ (Plus), PAGE UP, CTRL + + (Plus)/PAGE UP for fine zoom in
Zoom out
Mouse extra button 2,
- (Minus), PAGE DOWN, CTRL + - (Minus)/PAGE DOWN for fine zoom out
Zoom by rectangle
CTRL + Right mouse button,
Middle mouse button,
CTRL + ALT + Left mouse button
Reset
CTRL + Right mouse button double-click,
Middle mouse button double-click,
CTRL + ALT + Left mouse button double-click
Reset axes
A, HOME
Copy bitmap
CTRL + C
Tracker
Left mouse button,
SHIFT + Left mouse button for points only tracker,
CTRL + Left mouse button for free tracker (show mouse coordinates basically),
