Version 1.5 | Published April 05, 2022 ©
Supported Protocols
Currently, Tracking Hub has native support for the following protocols:
  • FreeD (see Description of the FreeD protocol)
  • Shotoku
  • RTHead
  • NCam
  • Xpecto
  • XML Tracking: A special feature, a self-definable protocol for special solutions
  • Motion Analysis (it is possible to work with two MA instances)
  • mo-sys (with lens information)
  • Trackmen
  • Trackmen Mocap
  • Vicon
  • Libero
  • Spidercam
  • spidercamfd
  • Spidercam-frameb
  • Flair
  • Thoma
  • Stype A5
  • Stype HF
  • Camreginfo
  • Technodolly
  • Skycam
  • Gsgeopoint
  • Kuper
  • FreeDa0
  • Telemetrics
  • hd-Skycam
  • kromanov
  • Arraiy (only with VIZRT lensfile)
  • Sky X Cam
  • Cable Cam
  • Eagle Eye
  • GeoPro
Important: Tracking Hub is able to parse these protocols and send the translated data to Viz Engine. Being in this list does not mean the tracking system is certified!
