Version 1.5 | Published April 05, 2022 ©
Topology Panel
The Topology Panel shows a representation of the tracking systems, the connection to a Viz Engine and which Viz Engine services are in use.
images/download/attachments/76799008/image2020-2-14_12-47-50.png
Tracking Systems
The Tracking System panel represents the tracking software in the studio. Click on a tracking system icon to view its properties (see Parameter Panel). A line from the tracking system represents a connection to a Rig.
images/download/attachments/76799008/setup_tracking_panel.png
Right-click Menu:
images/download/attachments/76799008/image2020-2-14_12-48-31.png
  • Connect to: Connects to a Rig.
  • Connect/Disconnect: Connects to or disconnects from the tracking system.
  • Analyze timing: See Analyze Time.
  • Analyze rawdata: Enables or disables the collection of raw data for analytical purposes.
  • Delete: Removes the Tracking System.
Right-click on a Bar:
images/download/attachments/76799008/setup_track_right_click.png
  • Reset bar’s min/max: Resets the minimum and maximum value of each bar.
  • Reset spectrum’s min/max: Resets the minimum and maximum value of the whole spectrum and each bar.
Rigs
images/download/attachments/76799008/image2020-2-14_12-49-8.png
A Rig is the interface between the Tracking System and Viz Engine. Click on any Rig icon to view its properties (see Parameter Panel). A line from a Rig on the left represents a connection to a tracking system (see Tracking Systems). A line from a Rig on the right represents a connection to a Service (see Services).
Rigs are defined as the following types:
  • Translation
  • Arm
  • Location Pivot Rotation
  • Pivot Rotation
  • Camera Standard (rotation order YXZ Pan - Tilt - Roll)
  • CameraXZY (rotation order YZX Pan - Roll - Tilt)
  • CameraYXZ (rotation order ZXY Roll - Tilt - Pan)
  • CameraFD (special design for Spidercam construction)
  • Object
  • Extended LensParameters
  • Lensfile
The Translation rig is for position data only, and provides the Tracking Hub with the following parameters:
  • pos_x
  • pos_y
  • pos_z
The Arm rig can be rotated in three dimensions, and starts with a swivel. It has a defined length with a defined direction, and offsets between swivel and length. Both the Translation and Arm rigs are used for camera systems such as Spidercam:
images/download/attachments/76799008/panels_20151030_143540.jpg
The Location Pivot Rotation rig is a rotation interface in the X-Z dimension, with center point (0/0). Pivot Rotation is a rotation rig with a definable center point. The rig provides the Tracking Hub with the following coordinates:
  • pivotx
  • pivoty
  • pivotz
Camera is a basic rig for tracked cameras. Object is a basic object for tracked objects.
Services
A Service is the element of a Viz Engine which is connected to the Tracking System through the Rig. Click on a Service icon to view its properties (see Parameter Panel). A line from the a Service represents a connection to a Rig (see Rigs).
images/download/attachments/76799008/setup_camera_panel.png
Available Services are:
  • Camera: Tracks a camera for Viz Engine.
  • Object: Tracks an object with Viz Engine.
  • Parameter: Provides all required data for the creation of the 3D View.
  • MoCap: Captures motion for Viz Engine.
  • Communication Timing: Sends timing information which are measured during tracking data acquisition.
  • Tracking Timing: Sends timing information which are measured during sending the data as service to the engines.
Right-click display object for additional menu:
images/download/attachments/76799008/setup_service_right_click.png
Topology Connection Lines
The Topology Connection Lines show the connections between each item in the Topology. Double-clicking a Topology connection line between a Tracking System and a Rig opens the Tracking parameter routing window for the connection:
images/download/attachments/76799008/setup_cross_parameters.png
Topology Colors
The colors of the icons in the Topology view show the working condition:
  • Green: Everything is OK and in regular working condition.
  • Grey: The tracker is not connected or deactivated.
  • Orange: The Service or Tracker state is in warning condition. See the log or message for more information.
  • Red: The Service or Tracker state has a serious error. See log or message for more information.
Motion Capturing with Motion Analysis
Motion Capturing is a special way of collecting and forwarding data to an Engine. This mode transmits movements of a person or people instead of camera positions. For these special procedures, there is a new rig and a new service available.
Selectable via the menu:
  • Rigs > Add MoCap
  • Services > Add MoCap service
images/download/attachments/76799008/image2020-2-14_12-51-37.png
Connect the Motion Analysis Tracking System to the MoCap Rig as usual.
images/download/attachments/76799008/image2018-7-3_13-22-41.png
In this case, there is just one axis available.
images/download/attachments/76799008/image2018-7-3_13-24-17.png
The name of the axis depends on the used name in MA's Cortex. Mocap Service can be used as other services.
