Version 1.5 | Published April 05, 2022 ©
Installation Folders
The default installations folders are
  • C:\Program Files\vizrt\VizTH
  • C:\Program Files\vizrt\Studio Manager
Files which are created or can be modified
are located in %ProgramData%\vizrt\VizTH, and include:
  • Config files.
  • Crash dump files.
Temporary files are located at: %TMP%\vizrt\VizEngine, which usually resolves to C:\Users\<user name>\AppData\Local\Temp\vizrt\VizEngine. This folder is referenced as <viz temp folder> throughout this User Guide.
