Control Clock
images/download/attachments/27789238/viz_icons_controlclock.png
The Control Clock plug-in allows the user to set time for a clock as well as controlling several clock functions. The clock object is a text container in the scene with the clock function enabled.
Control Clock Properties
images/download/attachments/27789238/plugins_container_controlclock_editor_r.png
  • Expose Limit: Enable the user set a limit for the clock
  • Expose Direction: Enable the user to choose the direction for the clock
  • Action: Set the clock action that will be the default value in the control client’s clock editor
  • Input Value: Show the current value for the plug-in. It is not necessary to set any value here. It is normally only used for debugging purposes
