Scene Tree Menu
At the top of the Scene Tree area is the control menu:
images/download/attachments/27788137/tree_knowledge_scene_tree_log.png
  • Tree
    • Tree: Shows an overview of all the Containers in the Scene (see Tree Button).
    • Sort: Sorts the items in the Scene Tree based upon criteria that are set in the Display area (see Sort Button).
    • Search: Search items in the Scene Tree (see Search Button).
  • Media Assets Manager: In the Media Asset Manager, add Media Assets to a Scene as:
    • DVE
    • Texture
  • images/download/attachments/27788137/tree_knowledge_log_error.png Scene Log: Shows if an error occurs. Opens the Log window, which gives information about the loading process of the Scene, such as errors, for example if a plug-in is not found. Click on it to open the Scene Log.
    • If the log window is closed, but not cleared, the exclamation mark icon will show in gray. It will show red again if another fault occurs.
  • images/download/attachments/27788137/tree_knowledge_videoeditoricon.png Media Asset Properties Editor: Click on the icon at any time to open the Media Asset Panel Editor panel of the Scene Settings.
  • images/download/attachments/27788137/tree_knowledge_sp_icon.png Scene plug-in: Click on the icon at any time to open the Plug-in panel panel of the Scene Settings. In the plug-in panel, Scene plug-ins can be added to the current Scene. This icon turns orange when a Scene contains a Scene plug-in. Click on the icon to view the Scene plug-in properties panel.
  • images/download/attachments/27788137/tree_knowledge_scene_tree_info.png Scene Info: Opens the Scene Information window, which gives information about the Scene entered by the designer. Shows orange if information is available.
Tree Button
If the Tree button is clicked, all Containers are shown in the hierarchical Scene Tree View.
  • images/download/attachments/27788137/tree_knowledge_tree_favorites.png Show/Hide Favorites: Show or hide the Favorites Bar.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_lockunlock.png Lock/Unlock: Lock or unlock the ability to modify the transformation of selected Containers in the Scene Editor. Middle mouse click to lock or unlock all Containers.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_showornot.png Show/Hide: Show or hide selected Containers in the Scene Editor, and eventually in the final rendered output. Middle mouse click to show or hide all Containers.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_openclose.png Expand/Collapse: Expand or collapse the Scene Tree.
  • images/download/attachments/27788137/tree_knowledge_script_startstop.png Start/Stop: Start (compiles) or stop all Container scripts.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_zoom_inout.png Zoom In/Zoom Out: Zoom in (larger Containers) or Zoom out (smaller Containers) on the Container tree. Zoom out applies smaller icons to the Containers. This gives a better overview, especially in complex Scenes.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_groupungroup.png Group/Ungroup: Create a new container group, and places the selected Containers as Sub-Containers. The Ungroup button moves the Sub-Containers up one level.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_splitjoin.png Merge/Split: Merge the selected Containers to one compound object, or split an existing compound object.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_addgroup.png Create Group: Create a new empty group at the top of the Scene Tree. Drag the icon to place a new group at a specific place in the Scene Tree.
  • images/download/attachments/27788137/tree_knowledge_tree_colours.png Color: Apply a color to selected Containers. You can define text labels for the colors in the Global Settings Panel to make them more descriptive.
  • images/download/attachments/27788137/tree_knowledge_refresh.png Refresh: Refresh the Scene Tree. Use this button if scripts have been deployed to change the Scene Tree.
Scene Tree View
images/download/attachments/27788137/tree_knowledge_scenetree.png
Sort Button
Click the Sort button to enable the Scene Tree Sort View, where the items in the Scene Tree can be sorted based on various criteria. A sorted Scene Tree makes it possible to analyze the Scene and optimize the performance.
images/download/attachments/27788137/tree_knowledge_sorttree.png
  • images/download/attachments/27788137/tree_knowledge_tree_favorites.png Show/Hide Favorites: Show or hide the Favorites Bar .
  • images/download/attachments/27788137/tree_knowledge_tree_sort_vertices.png Vector: Sort the Scene Tree by the number of vectors the Containers (which have Geometries) have. The Container with most vectors is shown on top.
  • images/download/attachments/27788137/tree_knowledge_tree_sort_rtime.png Render Time: Sort the Scene Tree by the time it takes to render the Containers. Each Container is shown with the percentage of total time the Scene takes to be rendered. The Container with the highest percentage is shown on top.
  • images/download/attachments/27788137/tree_knowledge_tree_colours.png Sort by Colors: Filter Containers by color. Click on the icon, and click on each required color to filter.
    images/download/attachments/27788137/tree_knowledge_sort_colours.png
  • images/download/attachments/27788137/tree_knowledge_tree_sort_texsize.png Texture Size: Sort the Scene Tree by the size of the Container texture. The Container with the largest texture size is shown on top.
  • images/download/attachments/27788137/tree_knowledge_tree_sort_unique.png Unique: Show unique group objects with the same Texture only once. This option is only available if the Containers are sorted by Texture size (click the Texture Size button).
  • images/download/attachments/27788137/tree_knowledge_treesortinput.png The input box defines the number of search results displayed. Click <R> to set to default number of search results (20).
images/download/attachments/27788137/tree_knowledge_scene_tree_sort_display.png
Search Button
Click Search button to access the search controls. Here you can search for items in the scene tree, and inside containers scripts and scene scripts.
images/download/attachments/27788137/SearchBar.jpg
Use the different buttons to search for specific properties of the Scene (see Search Options) or highlight the search results. Search results are highlighted in the Scene Tree, and the number of search results are displayed.
Example: If a plug-in (for example Extrude) is dragged to Properties, clicking the Show all button will highlight all occurrences of that plug-in within the Scene Tree.
Search Options
images/download/attachments/27788137/SearchBar_colored.jpg
  • Name: Search for Containers with a specified name. Type the search string in the Name field (1). Wildcards, for example *, ? and [ ], may be used in the search.
    Tip: By default, the text wildcard character, *, is added to the start and at the end of the search string. This means that searching for "player" will find any node named "player" in the scene tree, and also nodes named for instance player-name or secondplayername.
    Click on the drop arrow (2) to show extended search parameters. Options are to search for Parameter, Values and plug-in names within the Scene. When the extended parameters option is active, all other search options than Name are inactive.
  • images/download/attachments/27788137/SearchContainer.jpg Search for Containers: Click this button to search in the tree for container properties.
  • images/download/attachments/27788137/SearchScript.jpg Search in Script: Click this button to search all scripts in your scene, container scripts and scene scripts.
  • images/download/attachments/27788137/ShowinScript.jpg Show in Script: Click this button to show the search results inside the script editor.
  • images/download/attachments/27788137/tree_knowledge_drop_site_low.png Drop area for Properties: Drag an item from the Server Panel, from a Container in the Scene Tree or from the Favorites Bar to search for its occurrence within the Scene.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_hide.png Hidden: Search for all hidden Containers.
  • images/download/attachments/27788137/tree_knowledge_tree_basic_lock.png Locked: Search for all locked Containers.
  • images/download/attachments/27788137/tree_knowledge_search_inactive_properties.png Inactive Properties: Search for Containers that contain properties that are set to inactive.
  • images/download/attachments/27788137/tree_knowledge_colortiles.png Color: Searches for all Containers with the assigned color tile.
Show Search Results
  • images/download/attachments/27788137/tree_knowledge_tree_search_next.png Show Next: Show the next result.
  • images/download/attachments/27788137/tree_knowledge_tree_search_previous.png Show Previous: Show the previous result.
  • images/download/attachments/27788137/tree_knowledge_tree_search_first.png Show First: Show the first result.
  • images/download/attachments/27788137/tree_knowledge_tree_search_last.png Show Last: Show the last result.
  • images/download/attachments/27788137/tree_knowledge_tree_search_all.png Show All: Show all results.
  • images/download/attachments/27788137/found.jpg Search Results: Shows how many results were found.
    Tip: If a specific plug-in is no longer to be used in a Scene, make a search for the plug-in and select Show All to highlight all the results. Drag one of the highlighted plug-ins to the trash can, and all the highlighted plug-ins will be deleted from the Scene.
    Tip: If Show all search results is selected, the transformation properties can be changed for all highlighted Containers.
    Tip: If Show all search results is selected, a plug-in or an item (except a Scene) can be added to all the highlighted Containers (drag a plug-in or an item to one of the highlighted Containers).
To Do an Extended Search
images/download/attachments/27788137/ExtendedSearch.jpg
  1. Go to the Scene Tree and click Search.
  2. Click drop arrow to show the extended search options (1).
  3. Enter a search criteria. The search criteria can be a combination of Parameter, Value and plug-in name. Below are some examples:
    • Parameter:tesselation, width, *show*
    • Value:20, *10.0*
    • Plugin:*rect*
  4. Press <Enter>.
  5. Use the Show Search Results buttons to navigate the Scene Tree.
    Tip: Use the label names in the plug-in editors as a search criteria. If there is no hit, use the asterisk (*) symbol.
To Do a Script Search
images/download/attachments/27788137/SearchScriptstart.jpg
  1. Load a scene that contains scripts, either scene scripts, container scripts, or both script types.
  2. Go to the Scene Tree and click Search to open the search fields.
  3. Enter your search term, then click the Search Script icon.
  4. The search result contains all container scripts and scene scripts that contain the search term within the script code.
  5. Clicking the Show in Script button to open the selected script and highlight the search result inside the script window:
    images/download/attachments/27788137/SearchResults.jpg
  6. You can also click Scene Script to open the scene Script Editor, highlighting the search result inside the script window:
    images/download/attachments/27788137/ShowInSceneScript.jpg
Tip: You can also do an advanced search inside the script editor, to search not just a single script but in all scripts used in the scene.
