pxTurbDissolve and pxTurbWipe
images/download/attachments/27789751/plugins_shader_pxtdissolve_wipe.png
Both pxTurbDissolve and pxTurbWipe utilize the native multi-texturing support of Viz Artist.
pxTurbWipe includes the parameters of Angle and Softness.
To apply TubDissolve and/or TurbWipe
  1. Insert an image into the scene tree.
  2. Go to the image’s texture editor and make sure that the texture Unit is set to 1 and the Inheritable option is active.
    This will be your Image A in an A-B transition paradigm.
  3. Place a child image underneath the first one.
    This will be Image B.
  4. In Image B’s texture editor, set the Unit to 2 and make sure that the Inheritable option is inactive.
  5. Apply the Dissolve plug-in to the Image A (the parent image).
  6. In the plug-in editor, first adjust the Transition, followed by the other parameters, as per your liking.
Note: This plug-in is located in: Built Ins -> Shader -> PixelFX
