Pinnacle Targa 3200
Pinnacle Targa 3200 was Vizrt's standard board for SD Viz systems until 2007, and was typically used with IBM ZPro 6221, IBM Z-Pro 6223 and HP xw8200.
Configuration History
Driver - CODI v2.42
Revision - 3213. Revision 3213 crashes the machine when used with CODI v2.41rc13.
Driver - CODI v2.41rc13
Revision - 3212, 3214. Installation of CODI Compatibility Patch for revision 3214 is no more required.
Driver -CODI v2.42
Revision - 3212, 3213, 3214. Installation of CODI Compatibility Patch is required.
Driver -CODI v2.2 RC4
Revision -3212, 3213.
