MOS Profile Support
Gateway supports the following MOS profiles:
Profile
Definition
Supported
Vizrt Comment
0
Basic Communications
yes
1
Basic Object Based Workflow
yes
2
Basic Running Order/Content List Workflow
yes
3
Advanced Object Based Workflow
partly
Only mosItemReplace is used.
4
Advanced RO/Content List Workflow
yes
5
Item Control
partly
Only roCtrl is supported.
6
MOS Redirection
yes
7
MOS RO/Content List Modification
no
MOS Protocol Support
Gateway supports these MOS protocol versions:
Protocol version
Supported
2.6
yes
2.8.0
yes
2.8.1
yes*
2.8.2
yes*
2.8.3
yes*
2.8.4
yes*
2.8.5
yes*
4.0.0
yes**
*Both the Media Sequencer hosting the central Gateway and Media Sequencer clients must be upgraded to version 5.3 or later to support MOS Protocol version 2.8.1 or later.
**The Media Sequencer hosting the central Gateway must be upgraded to 5.6 to support MOS Protocol version 4.0.0. The Media Sequencer clients must be upgraded to at least 5.3, but in order to support secure websocket communication with the central Gateway, the clients must be upgraded to 5.6 as well.
