Version 3.8.1 | Published January 22, 2018 ©
Manual Installation
When installing Viz Mosart (and upgrading to new Viz Mosart versions), it is recommended to use the Viz Mosart Installation Administrator. It is however, possible to run the Viz Mosart Installation Files manually from Windows Explorer.
To perform a manual installation
Download all relevant Viz Mosart Installation Files to the preferred location.
Default location is C:\Mosart\Installers You are advised to make a sub-directory for the installers for a particular version/build containing all the MSI installer-files and any other supplemental files. This directory should be named using the Release.Version.Patch.Build naming convention, for example: C:\Mosart\Installers\3.7.0.24523 for Mosart 3.7.0 build 24523 -
Double-click an MSI installation file, and follow the prompts to complete the installation.
Repeat the previous step for all relevant installation files.
