AV Automation Devices - General
Standby at startup
Select the drivers to start in standby mode. They must be taken out of standby manually.
Show in Console
Autotake timing: Adds timing to the log window. Used for debugging purposes.
Diagnostics
Trace: Adds logging information to console used for dbugview.
Verbose: Increases logging information from AV Automation to the log file.
Directtakes
Directtake On Reload: The number of the directtake template to be fired upon re-loading the rundown.
Directtake On Become Active: The number of the directtake template to be fired when the server becomes active from idle, when switching between main and backup Viz Mosart servers.
Directtake On Become Idle: The number of the directtake template to be fired when the server becomes idle from active, when switching between main and backup Viz Mosart servers.
Crossover
Directtake on Activate: The direct take number to be taken when this server goes active in crossover switch.
Directtake on Inactivate: The direct take number to be taken when this server goes inactive in crossover switch.
Redundancy
UseMirroring: Check to enable mirroring. Upon enabling mirroring on both main and backup server, the settings will be synchronized.
Hostname: Hostname or IP address of the Backup Server if using Main Server, and vice versa.
Port: IP port number of the Backup Server if using Main Server, and vice versa.
Media Router
Use for: Select which controls should be used by the Media Router.
Name: Media router’s hostname or IP address.
Port: Media router’s connection port number.
Connect Salvo: The salvo name to be taken when this server connects after restart. Default: Current
Active Salvo: The salvo name to be taken when this server becomes the active server from being idle. Default: Slave
Idle Salvo: The salvo name to be taken when this server becomes idle after being active. Default: ReleaseAll
