Viz Mosart Client
The main components that make up Viz Mosart Client are:
  • Viz Mosart GUI: Fullscreen Windows application used to control and monitor the Viz Mosart rundown.
  • Audio Panel: Fullscreen Windows application used to control and monitor software audio faders.
  • Timing Display: Fullscreen Windows application used to display various timing information from the Viz Mosart rundown.
  • Audio Player: Used to play out audio files located on the file system.
    The additional Viz Mosart Client applications are:
  • Multiple instances of the above applications may run on any workstation connected to the same network as the Viz Mosart Server.
  • All instances of Viz Mosart software must be running the same Viz Mosart version with a standard OS across all Viz Mosart client machines.
Viz Mosart GUI
images/download/attachments/54012069/about_mosart-gui-icon.png
The Viz Mosart GUI workstation is a standalone networked PC with a single instance of the Viz Mosart GUI application (MosartMultiGui) run in full-screen mode. Several PCs can run the same software component, for example a backup GUI PC.
The Viz Mosart GUI is the main control interface for the Viz Mosart Server. The Director can run the production from a single key press on the workstation keyboard.
images/download/attachments/54012069/about_mosart-gui-window-resize.png
Alternate configurations may also host a fader panel and a Timing Display, it is preferable each Viz Mosart Client application run on a standalone networked PC.
The Viz Mosart GUI is described in detail in the Viz Mosart User’s Guide.
Audio Panel
images/download/attachments/54012069/about_audio-panel-window-resize.png
Audio Panel (Server)
The Audio Panel (AudioPanel) enables the use of a Behringer BCF2000 or JL Cooper MXL with Viz Mosart Server. This application controls data transmission between the physical hardware panel and AV Automation on the Viz Mosart Server.
Audio Panel (Client)
images/download/attachments/54012069/about_audio-panel-icon.png
The Audio Panel (Client) is a software representation of the audio mixer connected to the Viz Mosart Server. It is a replication of current faders, on air faders, and faders in ‘preview’.
The Audio Panel is described in detail in the Viz Mosart User’s Guide.
Timing Display
images/download/attachments/54012069/about_timing-display-window-resize.png
The Timing Display (WPFTimingInfo) is used to provide timing information to the studio control room and the studio floor.
The Timing Display is synchronized to the current rundown in the Viz Mosart GUI, and you can run as many customized Timing Display applications as you need for the production.
The Timing Display is described in detail in the Viz Mosart User’s Guide.
Audio Player
The Audio Player is part of the Viz Mosart installation and may be used to play out audio files located on the file system. This is useful to play out audio files that are used on a regular basis, such as for openers and audio-beds.
Note: A broadcast sound card is required for audio output. If you are running the Audio Player on a Windows Server, also install Windows Audio features on this machine, otherwise the various audio formats will not work.
images/download/attachments/54012069/about_audio-player-gui.png
Note: The Audio Player replaces the discontinued Soundfile Player.
The Audio Player is described in detail in the Viz Mosart User’s Guide.
ActiveX
images/download/attachments/54012069/about_activex-pkg.png
The ActiveX is used to insert Viz Mosart template information into the Newsroom System script. It is compatible with any newsroom system that allows ActiveX plugins.
The ActiveX list displays the first template name result it finds under NCS tags in Newsroom Settings. The user selects a Viz Mosart template type and variant, which can then be dragged into an entry in the Viz Mosart rundown. When the script is saved, information is pushed to Manus Administrator and the active rundown in the Viz Mosart GUI.
The ActiveX is installed as a standalone component and is independent of the version of Viz Mosart Server used.
Viz Mosart has its own ActiveX NCS plugin. The plugin gives users the ability to insert Viz Mosart commands to the scripts from a list of available Viz Mosart templates.
The templates and transition effects that are shown in the ActiveX may also depend on the value of Studio Setup in AV Automation > Audio and Video Setup.
When a particular Studio Setup is selected in the ActiveX (in the second dropdown box), then only effects with this studio setup (as defined in AV Automation > Audio and Video Setup) are available in the Transition dropdown. Effects with no studio setup defined, will be global effects and will always appear in the Transition dropdown.
iNews Timer
The iNews Timer allows for accurate timing of the production in iNews. It is used to synchronize the current on-air story in the Viz Mosart GUI to the correct corresponding entry in iNews.
