Version 5.0 | Published November 09, 2022 ©
AV Automation
AV Automation (MMAVAutomation) forms the bridge between Viz Mosart and the devices (for example a vision mixer or video server) in the studio. It also controls full-screen graphics (but not Overlay Graphics engines), which from a Mosart perspective, are treated as clips.
Overview
images/download/attachments/72115600/AvAstart.png
The principal tasks for AV Automation are:
  • To Cue a clip (prepare) when in preview
  • To Play a clip when taken on air
  • To manage control commands to studio devices.
All device drivers are stored in AV Automation, offering the administrator a single point of configuration.
On the fly commands can then be issued directly to each device through the Viz Mosart GUI, or as pre-programmed operations driven by the rundown submitted through the Newsroom System.
All device commands are stored as predefined Viz Mosart templates. They exist in the Template Editor, and are saved in C:\channeltemplates or in a template database.
AV Automation is the device handler of Viz Mosart. This application communicates with all connected devices such as cameras, video servers and vision mixers.
As well as presenting tools for configuring these devices, it includes Template Editor, for defining and customizing templates.
images/download/attachments/72115600/AVAutomation.png
Menu Description
images/download/attachments/72115600/image2019-8-9_19-51-20.png
For more information on the concepts of template set, Directtakes, and direct take templates, please refer to the Template Sets section in the Templates chapter in the User guide.
  • Standby: Lists all configured devices and their connection status (Green: connected, Red: not connected, Orange: standby).
    images/download/attachments/72115600/image2020-1-17_18-10-36.png
    From this menu, a device can be placed in Standby (or taken out of Standby). (Standby means the device is not under control of Viz Mosart; no commands will be sent to it from Mosart.)
    The Viz Mosart operator can also perform this action from the main UI. See the Viz Mosart User Interface section of the Viz Mosart User Guide, under Main Menu, Standby for further details.
  • Idle: This is an indicator that AV Automation is in idle mode, not a menu option. In this state, the menu bar turns orange.
    images/download/attachments/72115600/image2020-1-17_16-49-30.png
    As long as AV Automation is not in idle mode, there is no 'Idle' in the menu bar.
Logging and Status
Below the fader and switch representations are three monitoring panels.
Logging Panel
To the left is a Logging panel with time stamped event details. Logging is disabled by default.
To Enable Logging
There are two options:
  • Right-click in the panel and select Enable
  • In Properties > Shortcut> Target, add the command parameter enable_logwindow.
    images/download/attachments/72115600/image2020-9-23_7-36-23.png
    Logging will then be enabled at AVAutomation start-up.
To Clear Logging
  • Clear the Logging panel by double-clicking in the panel.
The following AV Automation topics are presented:
