Version 5.0 | Published November 09, 2022 ©
Control Commands in Templates
A Mosart control command can be triggered from a template, executed when the template is taken (Command On Take), at continue points (Continue Points) or when the template is taken out (Command On Take Out).
Note:
  • A Mosart template can trigger multiple control commands.
  • A (not-templated) control command can trigger a Mosart template, often used for a DirectTake template.
Working with Control Commands
This is done through AV Automation > Devices > Template Editor > Template > Properties > Control Commands tab.
images/download/attachments/95400245/controVS.png
The figure above shows a single (video) control command to be executed when the template is taken. Multiple control commands can be assigned here.
It is also possible to assign control commands to be executed at continue points and when the template is taken out.
The latter has limitation since the Parameter setting is not available. In this context it may be useful to trigger a direct take at this place.
Adding a Control Command
To Add a Control Command
images/download/attachments/95400245/templates_template-properties.png
Command On Take
When selected, the commands inserted in Control commands Take are executed when the template is taken to Program or On Air.
By setting a Newsroom tag as a parameter in the OnTake-commands, the user can set the parameter from the NCS. When the user is using the ActiveX to add a template to the rundown, a text box is visible, requesting this value.
Continue Points
When selected, the commands inserted in Continue Points will be taken when pressing TAKE NEXT (default: F12). Viz Mosart executes this continue point from within the primary template in which it is inserted. Each line represents a new Continue Point.
  • Cue Next Item Index: Enter the line number (for example, 0, 1, 2, 3) of the continue point that executes a cue for the next/following Primary object. If empty, Viz Mosart cues when entering the last continue point in the list.
  • Autotake: Insert the autotake time, in frames. The control command continue-point is then automatically taken after that time.
Command on Take Out
The commands inserted here are executed when the template is taken from the program, taken Off Air, or at the end of the template. Only a single command can be used in Command On Take Out, and it does accept any parameters.
Command Values and Parameters
Note: Parameters marked with (*) do not work for templates.
Note: It is not possible to enter a Parameter in the Control command Take Out section.
COMMAND
Value
Parameter
Description
ACCESSORIES
TAKE_NEXT
AUDIO
FADE_MANUAL
Toggle fade manual.
FADE_OUT_KEEPS
Fader rate
Faders that are set as "keep level" in the template On Air are faded out. Will also work when new templates have been taken in between the 'keep' action and the FADE_OUT_KEEPS.
FADE_DOWN SECONDARY_AUDIO
Fader rate
Viz Mosart fades down relevant audio sources not connected to the video currently On Air.
FADE_UP SECONDARY_AUDIO
Fader rate
Viz Mosart fades up relevant audio sources not connected to the video currently On Air, when cutting between sources.
SET_LEVEL_2_ONAIR
The second level for faders in the template which are On Air are set.
SET_LEVEL_2_PREVIEW
The second level for faders in the template are set on the template which is in preview, and be performed on next transition.
FREEZE_AUDIO
All sound faders are frozen, and do not respond to commands from templates. This command is a toggle function, and is thus NOT suited for use from a template.
AUTOTAKE
N/A
AUTOTRANS
PP, ME1, ME2, ME3, ME4
MixEffect (MIX OR WIPE) + Transitionrate
For example: MIX 33, WIPE 10.
Note: The Effect cannot be used.
AUX, Default
CROSSOVERCOMMAND
N/A
DEVICE_PROPERTY
CAMERA CONTROL
See next column.
Note: This is for camera robotics.
The 'DEVICE_PROPERTY' control command with value 'CAMERA CONTROL' is only used as a way to set speed (Camerobot) and presenter (Camerobot/FxMotion) from a template.
Details for Camerobot Presenter:
ANCHOR=pos1:presenter1[,pos2:presenter2]…
The position and presenter is given as a pair divided by ‘:’.
Multiple position-presenter pairs are possible, separated by ‘,’. images/download/attachments/95400245/Template_properties_closer.png
Note: The position is a string and does not have to be a number.
Details for Camerobot Time:
If Time =1 (>0), Viz Mosart sends MATRIX_MOVE_MPOS command to Camerobot,
while if Time = 0 Viz Mosart sends MATRIX_CUT_MPOS command Camerobot.
AUDIO
demands <fields> structure as parameter with
parameter1=AUDIO,
parmeter2=key,
parameter3=value
OR
connectionstring style
Note: This is for an audio mixer.
DEVICE_STANDBY
AUDIO_MIXER, GPI, LIGHTS, LOUDNESS, ROUTER, SOUND_PLAYER, SUBTITLING, VIDEO_SERVER, VIDEO_SWITCHER, VIDEO_WALL, VIRTUAL_SET, WEATHER
ON
OFF
TOGGLE
ON: The device chosen (in Value) is put in Standby.
OFF: The device chosen (in Value) is taken out of Standby.
TOGGLE: The Standby status (ON/OFF) of the device chosen (in Value) is toggled.
(If there are several devices of the chosen kind (e.g. video servers), all of them are affected.)
DEVICE_STANDBY
GRAPHICS (full-screen)
As above (ON/OFF/TOGGLE)
OR
engineno:[ON|OFF|TOGGLE]
(Example: 2:TOGGLE)
ON/OFF/TOGGLE: As above, applied to all graphics engines.
If an engine number is given, only the designated engine is affected.
DEVICE_STANDBY
ROBOTIC_CAMERA
OR
controller:[ON|OFF|TOGGLE]
(Example: 1:ON)
OR
controller:camera:[ON|OFF|TOGGLE]
(Example: 1:2:ON)
ON/OFF/TOGGLE: As above, applied to all cameras on all controllers.
If a controller (but no camera) is given, only the cameras on the designated controller are affected.
If both a controller and a camera is given, only the designated camera is affected.
DEVICE_STANDBY
OVERLAY_GRAPHICS
OR
Engine No:[ON|OFF|TOGGLE]
For example:
2:TOGGLE: Toggles Engine 2 Standby status)
ON/OFF/TOGGLE: Applied to all overlay graphics (all controllers and corresponding engines).
Note: Only engine number is supported.
Engine numbers are shown in the list of active engines in Overlay Graphics Interface and followed by '/' and destination name of the engine.
(Engine Handler, Destinations, Controller have no effect).
DIRECTTAKE
The Recall Nr (see Template Properties) of the direct take template to execute
Executes the direct take template given by Value.
DVE
FORWARD
REVERSE
Recall forward/reverse EMEM
n/a
COMMAND
Value
Parameter
Description
ENABLE_GRAPHICS_
MIRRORING
n/a
FULLSCREEN_GRAPHICS
CONTINUE_FULLSCREEN
AUTO
Continue Command Only: The AUTO parameter will replace the continue command with the number of continue points in the graphics item.
The number of continue points is taken from the graphics_continuecount field.
Examples:
AUTO+1: The number of continue counts from the graphics + 1
AUTO-2: The number of continue counts from the graphics - 2
FULLSCREEN_GRAPHICS
CONTINUE_FULLSCREEN
Engine no
The target output fullscreen engine number to execute the action on. (e.g. 1,2,3 )
MACRO
Engine no : macro
The target output fullscreen engine number to execute the action on. (e.g. 1,2,3 ) and Macro name.
The engine number must be same as the number defined in AV Automation
GRAPHICSPROFILE
N/A
HOLD_AUDIO_
TRANSITION
N/A
HOLD_VIDEO_
TRANSITION
N/A
LIGHT
N/A
MARKER
N/A
NCS
START_STATUS,
STOP_STATUS
RUNDOWN
STORY
ITEM
Specific for Open Media
NEXT_CUE_DELAY
EXTEND
A number of frames
If there is a pending cue (when this control command is executed), this cue is postponed by the number of frames given.
Otherwise (no pending cue), the next cue operation will be additionally delayed by the number of frames given. (I.e., the value will be added to the sum of the settings
OVERLAY_GRAPHICS
CLEAR
Destination or Render (Engine no.)
Destination or Render (Engine no.) to clear the graphics from.
Numerical value: Render (Engine no.)
Non-numerical value: Destination.
CONTINUE
Engine no
TAKE_MANUAL_OUT
Destination or Empty
Destination to take out the graphics from.
Empty or Numerical value: Takes out all the graphics
MACRO
Engine no : macro
For example: 4:macrohere
PRETAKE_NEXT_OVERLAY
Render (engine no)
TAKE_NEXT_OVERLAY,
TAKE_NAMED_OVERLAY
OVERLAY_TO_MANUAL
Parameter 1: ONAIR (default), PREVIEW.
Parameter 2: Comma-separated list of handler names
Parameter 3: AUTOMATIC (default) / MANUAL
Parameter 2 and Parameter 3 must be separated by a semicolon. (E.g. WALL,DSK;MANUAL.)
For more details, see Viz Mosart User Interface > Keyboard Shortcuts > Control Command Keys > OVERLAY_TO_MANUAL in the Viz Mosart User Guide).
Note : If there is no semicolon after Parameter 2; nothing to the right of the semicolon; or Parameter 3 has any value other than 'MANUAL', then Parameter 3 gets the default value ‘AUTOMATIC’.
PLAY_STORY
N/A
RECORD
PREPARE,
START,
STOP
Split parameters using,
- first: clipname,
- second: recorder (optional),
- third: port name (default Rec),
- fourth: group name (default Rec)
For example: clip33,recorder1,Rec,Rec
RELEASE_BACKGROUND
N/A
RUNDOWN_NCS_
RESYNC
N/A
SEQUENCE
LOOP
Sets a running sequence to start looping
STOP_LOOP
Stops running a looped sequence in loop
STOP
Stops a running sequence
START
Restarts a previously stopped sequence
SET_AUX_CROSSPOINT
N/A
SET_CROSSPOINT
AUX
Default
bus (A,B,C,D) : xpoint
If layers are supported by the driver (e.g. vizrt-ips) it is possible to also specify the layer (A,B,C,D) in addition to the crosspoint.
Two arguments are supported separated by semicolon. First parameter is crosspoint, the second is layer.
If no semicolon is used the value is interpreted as crosspoint only and bus A is used.
Example: B:CAM2
SET_CURRENT_ME
AUX
Default
SET_VIDEOSERVER_
SALVO
N/A
Not implemented for templates
STUDIOSETTUP
SWITCH_GRAPHICS_
MIRRORING
TOGGLE,
ACTIVATE,
DE-ACTIVATE
SWITCH_VIDEOSERVER_
MIRRORING
N/A
TAKE_CONTINUE_POINT
N/A
TAKE_SERVER_TO_
PROGRAM
N/A
transRate (integer) - parameter.
Takes a video server port to program on a selected ME. For example: a video clip is running on a video wall.
The shortcut can then be used to take the last used/active video server to program.
TRANSITION_TYPE
CUT,
MIX
Rate
EFFECT
Effect no
TOGGLE
UNKNOWN
N/A
Default fallback. Does nothing.
VIDEO_PORT
N/A
Must be a comma separated list in the format:
command,port,parameter
For example: PLAY_PAUSE,A,PLAY.
For more details, see Viz Mosart User Interface > Keyboard Shortcuts > Video Port Control Commands > OVERLAY_TO_MANUAL in the Viz Mosart User Guide).
VIDEO_SERVER_GOTO
N/A
VIDEOWALLMODE
N/A
WEATHER
N/A
Parameters with Placeholders
Control command parameters can include placeholders which are then populated with values found among the fields of a currently On Air, Viz Mosart item. A placeholder is defined as a string of characters, within curly brackets {placeholder}.
For example, a placeholder can be useful for transmitting values from the NCS, for use as control commands that will be executed when the template is taken On Air.
Example: Providing the clip name to be recorded from NCS.
In NCS, a column can be created for giving the name of the clip to be recorded with Viz Mosart. Then, in Viz Mosart Newsroom settings, map the column in Story External Metadata as follows:
<mostag mostagname="NCScolumn" mosart_action="item_variable" action_value="NCS_filename" format_type="String" />
In Manus file, the Mosart item will have the following fields (the value Clip1 is given from NCS):
Mosart Item
<fields>
<field name="NCS_filename" value="Clip1" />
</fields>
Then, in Template Editor, the control command for the respective template is configured as follows:
Control Command
RECORD PREPARE {NCS_filename}_Test,Recorder,RecPort
When the template is executed, a clip with name Clip1_Test is prepared for recording.
