Important Terms
A number of glossary items in the table below refer to one another. If a definition contains an unfamiliar term, check for its explanation in the same table.
| Term | Definition |
The system that manages the assemblage of broadcast systems, meaning the camera, graphics, prompters, etc. for broadcast. During playout, the system sends control commands to Viz Multichannel. | |
Room serving as an operations centre where a facility or service can be monitored and controlled. A control room generally serves a single channel. | |
Applied on rules, a condition relates to a primary events. When defining a condition, one or more attributes must be selected: the user enters a value which the primary event attribute must meet. If the condition is met, then the associated template will be shown. See Working with Conditions. | |
Digital Video Effects. Video that is played through the Viz Engine and that can have 2D animation. | |
A playlist element. Can be a primary or secondary event. | |
For primary events, this field serves as the index on which the playlist updates are done. This identifies the primary event, and is the key to know which event is to be updated. | |
An item in a playlist. Can be a primary event or secondary event. | |
The department where the initial insertion of secondary events into the playlist takes place. When ready, it will be transferred to Master Control Room for the actual playout. The Multichannel client there is for scheduling. | |
Master control is the technical hub of a broadcast operation common among most over-the-air television stations and networks. It is distinct from production control rooms in television studios where the activities such as switching from camera to camera are coordinated. Typically there will be Multichannel client for last-minute changes and monitoring. | |
The Media Sequencer Engine (MSE) is a central software component used by Vizrt client applications. The Media Sequencer is a framework for defining and executing media elements. | |
The delay between the secondary events and its respective primary event. | |
A list of programs, typically for a single day. An external playlist can be imported from an automation or traffic system. A Viz Multichannel playlist is composed of primary and secondary events, and can be viewed in the Editing Area. | |
A primary or secondary event in a playlist. | |
A program in a playlist. Appears as the parent element. Templates and Viz Commands can be added as secondary events. | |
For imported (and subsequently updated) playlists, you can create sets of rules that govern how templates can be automatically associated with certain events within a playlist. Rules are useful when external playlists do not already contain Secondary Events. Rules are defined on a per-template basis. Both master and editable templates support rules. In addition, rules can also be applied to Viz Commands (see Defining Viz Command Elements). Rules are applied upon Importing Playlists from External Sources or Updating Playlists of external origin. | |
A graphic scene built in Viz Artist, before being imported into Viz Multichannel. | |
A child element of a primary event in a playlist. Can be a template or a Viz Command. | |
A graphic scene built in Viz Artist, after being imported into Viz Multichannel. Placed in a playlist as a secondary event. | |
The system for scheduling of program material, and in particular the advertisements, for the broadcast day. The result of this scheduling is a daily playlist for a channel, which is the input for Viz Multichannel. Depending on the system, it can also include the information for secondary events. | |
A control command initiated from the automation system telling Viz Multichannel to execute a certain command on a playlist event, such as LOAD, PLAY, STOP. The automation system uses a known protocol, such as VDCP, CII, GPI etc., to send the command. | |
The software, running on a standalone machine, that renders the 3D Viz graphics. |
