GPI
GPI is a type of Trigger that does not relate directly to a playlist event. From a list of available commands, you can define what Viz Multichannel will do when it receives any one of them from an external device.
Bits per second: Default is 9600.
Port: Select the relevant COM port on the Media Sequencer machine.
Stop bits: Default is 1.
Data bits: Default is 8.
Parity: Default is None.
Box Type: Default is SRC-8.
Flow Control: Default is None.
Each GPI Action is number DLn or DHn, where n is a sequential number, beginning from 0.
Under the Commands column, all the Viz Commands, editable templates and general actions such as show logo, remove logo, stop active playlist, etc. are available as options.
Description can be defined freely.
