Viz Pilot Edge is a newsroom component that is used to create, manage and deliver content to live and taped broadcast productions. Viz Pilot Edge can also be used as a Graphics Plugin user interface in NLE workflows.
Template Builder lets you make customized templates using the scene import or existing templates from Viz Pilot's Template Wizard.
Info: A key feature is that you can add custom HTML panels to templates, giving full control over the template through custom scripting and logic.
Key Features
  • Search for graphics templates, elements and media assets.
  • Add and edit content using an auto-generated Fill In Form.
  • Preview graphics.
  • Open and edit videos.
  • Save data elements to the database.
Workflow
  • Fill templates with content and store them as data elements.
  • Move data elements into the newsroom rundown.
  • Scenes are made in Viz Artist and imported into Template Builder, where templates are made.
  • Templates are edited and new templates can be made in Template Builder.
  • The template is saved in the Viz Pilot system and is available to newsroom and control room systems for playout.
Note: Changes in the UI made to a template in Template Builder are not available when opening the template in Template Wizard.
Feedback and Suggestions
Support
Copyright ©2025 Vizrt. All rights reserved.
Antivirus Considerations
