Viz Arc can be integrated with Viz Pilot Edge. In this workflow, Viz Arc actions can be browsed and selected, dragged to the newsroom rundown and played out by a control client like Viz Mosart.
Configuration
To enable this workflow, the Viz Arc system must support hosted MOS panels. Check the Viz Arc documentation for the URL of the Viz Arc Panel.
Info: In Viz Arc 1.8.1 the default URL is http://arc-host:9004/mos-plugin. For HTTPS the default port is 9005.
To make the Viz Arc panel appear in Viz Pilot Edge, add the following settings in PDS (see Pilot Data Server documentation on how to add Optional Database Parameters):
Parameter
Mandatory
Default Value if not set
Description
moseditor_arc_url
yes
The URL to the panel.
moseditor_arc_schema
no
http://www.vizrt.com/mosObj/vizarc/action
A unique identifier for the editor to be able to reopen Viz Arc actions from the rundown.
moseditor_arc_label
no
Viz Arc
Label appearing on the tab in Viz Pilot Edge.
Timing
To add timing to the Arc Actions, use the Playout Instructions.
  • Check Enable to instruct Viz Pilot Edge to use playout instructions.
  • Set the In time to the number of minutes and seconds when this Viz Arc action must be executed, relative to the story.
  • Set Trigger to TIMED.
If the Trigger is set to MANUAL, Viz Mosart does not play this item automatically, but marks it as a Manual item in the UI.
Note: Out and Duration are not yet supported for Viz Arc Actions as these actions do not support such events. Only the In time is relevant.
