Additional Components
Additional components are components with more specialized properties and features, and are not used as much as the standard components.
  • Wrap Fixed Unicode Memo Component
  • TrackBar Component
  • Mask Edit Component
  • Speed Button Component
  • DateTime Picker Component
  • Timer Component
images/download/attachments/28386144/twcomponents_wrapfixedunicodememo.png
This component is much like the Unicode Memo. However, there is a significant difference between the two. As the Unicode Memo stores its text as a list of strings, the Wrap Fixed Unicode Memo saves the text in the UTF8Text string property as one long text string. This avoids the problem of line breaks being added to the text provided that WordWrap is disabled. Line breaks added by the user is not removed.
TrackBar Component
images/download/attachments/28386144/twcomponents_trackbar.png
The TrackBar represents a position along a continuum using a slider and, optionally, tick marks. A track bar can also display a selected range and set minimum and maximum values. The selected range is marked by triangular ticks at the starting and ending positions of the selection.
Notable Properties
  • Max: Specifies the maximum size of an interval.
  • Min: Specifies the minimum size of an interval.
  • SelEnd: Specifies the position of the end point of the selection range.
  • SelStart: Specifies the position of the starting point of the selection range.
  • Position: Contains the current position of the slider.
Mask Edit Component
images/download/attachments/28386144/twcomponents_maskedit.png
Allows a user to enter and edit data, similar to an edit component, but provides a means to specify particular formats, such as a postal code or phone number. Mask Edit shares the properties of other Text controls.
Notable Properties
  • EditMask: Specifies the characters a user can enter into the masked edit control to valid characters and formats.
  • Text: Contains the formatted text based on the mask set by the EditMask property.
images/download/attachments/28386144/twcomponents_speedbutton.png
Use TSpeedButton to add a button to a group of buttons in a form. TSpeedButton introduces properties that can be used to set graphical images that represent the different button states (selected, unselected, disabled and so on). Use other properties to specify multiple images or to rearrange the images and text on the button.
images/download/attachments/28386144/twcomponents_vtw_speedbutton_onair.png
images/download/attachments/28386144/twcomponents_vtw_speedbutton_offair.png
TSpeedButton also introduces properties that allow speed buttons to work together as a group. Speed buttons are commonly grouped in panels to create specialized tool bars and tool palettes.
Notable Properties
  • GroupIndex: Buttons with the same property value (other than 0), work together as a group and can present mutually exclusive choices to the user.
Script Example
Sub InitForm
SpeedButton1.Color = clGray
SpeedButton2.Color = clRed
End Sub
Sub SpeedButton1Click(Sender)
SpeedButton1.Color = clLime
SpeedButton2.Color = clGray
End sub
Sub SpeedButton2Click(Sender)
End sub
images/download/attachments/28386144/twcomponents_icondatepicker.png
The TDateTimePicker component is used for entering dates or times. In dmComboBox date mode, it resembles a list box or combo box, except that the drop-down list is replaced with a calendar illustration; users can select a date from the calendar. Dates or times can also be selected by scrolling with Up and Down arrows and by typing. Use the .Date and .Time property to access the selected date/time from script.
Notable Properties
  • Date: Indicates the date entered by the user.
  • DateFormat: Determines whether the date format is long or short.
    DateMode: Can be used with a drop-down calendar or by the Up/Down arrows with which the user can adjust the date. (Applies only when Kind is dtkDate.)
  • Kind: Determines if date or time is shown.
  • Time: Indicates the time entered by the user.
Timer Component
images/download/attachments/28386144/twcomponents_icontimer.png
Use the Timer component to trigger an event after a measured interval. Write the code that is supposed to occur at the specified time inside the timer component’s OnTimer event.
Notable Properties
  • Interval: Determines how frequently the OnTimer event occurs. Specified in milliseconds. Default is 1000 (one second)
  • Enabled: Determines if the timer is active or not. The OnTimer event only occurs when the Enabled property is True
Script Example
The Timer event gets called at the interval specified (1000 = 1 second) and the current date and time is set in a text box.
images/download/attachments/28386144/twcomponents_vtw_timer_eventeditor.png
When the template is loaded it will be in Start mode
Sub Initform
Timer1.Enabled = False
TWColorButton1.Color = clLime
TWColorButton1.Caption = "Start"
End Sub
images/download/attachments/28386144/twcomponents_vtw_timer_guistart.png
When started, the Timer1Timer event adds the time Now to the combo box
Sub Timer1Timer(Sender)
TWUniComboBox1.Items.Add(Now)
End sub
images/download/attachments/28386144/twcomponents_vtw_timer_guistop.png
When the button is clicked, it either sets Timer1 to true or false, and at the same time changes color and caption.
Sub TWColorButton1Click(Sender)
if (Timer1.Enabled = True) Then
Else
TWColorButton1.Color = clRed
TWColorButton1.Caption = "Stop"
End If
End sub
