Viz Control Components
This section has information on the following topics:
  • Drag Edit Component
  • Value Control Component
  • Audio Control Component
  • Targa Control Component
  • Triplet Editor Component
Drag Edit Component
images/download/attachments/28386188/twcomponents_twedit.png
The TDragEdit component is used to set numeric values, either by entering the values using a numeric pad or using the mouse by clicking the text box and dragging in a horizontal direction to adjust the value.
Notable Properties
  • Enabled: Enables the control.
  • ReadOnly: Enables the value to be read only.
  • Text: Sets the text string associated with the control.
images/download/attachments/28386188/twcomponents_valuecontrol.png
The TWValueControl component is a generic component used for scripting to control values outside the scope of Template Wizard’s default components. It is therefore a good candidate in those situations where Template Wizard does not offer a default component for certain exposed Control plugins and properties.
Value Control can only be used with scripting, and is therefore (to the operator) a hidden component. However, you can expose it by using other components that can be used to assign values to the Value Control’s ControlValue property.
Notable Properties
  • ControlObjectName: Sets the exposed Control plugin property that Value Control should control (e.g. 01.kerning).
  • ControlValue: Sets the value that Control Object in Viz should receive in order to control the exposed Control plugin property.
Script Example
Sub TWUniButton1Click(Sender)
TWValueControl1.ControlValue = TWUniEdit1.Text
End sub
images/download/attachments/28386188/twcomponents_unix_sound.png
The VizAudioCtrl component is used to selected audio clips from a defined directory (e.g. share). Supported file formats for this control are mp3 and wav.
Notable Properties
  • _InitialDir: Sets the default directory/share from where the audio clips should be located.
  • ChannelID: Sets the Channel ID used by the scene in Viz for playing out audio.
  • Director: Sets the name of the director in the scene that controls the audio animation.
  • Filename: Sets the audio filename.
  • Keyframe: Specifies the Viz keyframe to control.
    Note: The _UnixShare property is deprecated.
images/download/attachments/28386188/twcomponents_softclip.png
The VizTargaCtrl component is used to selected video clips from a defined directory (e.g. share). Supported file formats for this control are dif, avi and dv.
Notable Properties
  • _InitialDir: Sets the default directory/share from where the video clips should be located.
  • ChannelID: Sets the Channel ID used by the scene in Viz for playing out video.
  • Director: Sets the name of the director in the scene that controls the video animation.
  • Filename: Sets the video filename.
The TripletEditor component is used to set control values exposed from Viz such as position and scaling that require control of three values (e.g. X, Y and Z).
Notable Properties
  • Max, Min: Sets the maximum and minimum values.
  • XValue, YValue, ZValue: Sets the parameters X, Y and Z.
