Getting Started
Template Wizard is a stand-alone application that can be started from the program menu, a desktop shortcut or from Director if it is installed on the same machine.
  • To start Template Wizard
  • To specify command line parameters for Template Wizard
  • To start Template Wizard from Director
images/download/attachments/28386015/branding_icon_template_wizard.png
  1. Open the program from the Windows Start Menu (Template Wizard), or the desktop icon.
  1. Right-click the Template Wizard desktop shortcut, and select Properties
  2. In the Properties window select the Shortcut tab.
  3. To start multiple instances of Template Wizard add -duplicates to the Target path.
    • "%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -duplicates
      Note: When starting a duplicate instance you will most probably receive a socket error. Confirm it and you will be able to run duplicate instances of Template Wizard.
  4. To specify the Media Sequencer to connect to, add -mse <host> to the Target path.
    • "%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -mse <host>
  5. To specify the database to connect to, add -db <connect string> to the Target path.
    • "%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -db <connect string>
  6. To specify the inifile to use, add -inifile <inifile> to the Target path.
    • "%ProgramFiles(x86)%\vizrt\Viz Pilot x.y\VizTemplateWizard.exe" -inifile <inifile>
  1. Either, select Template Wizard on the Tools menu,
  2. Or, right-click a template in the template list, and select Edit Template on the context menu.
    images/download/attachments/28386015/twgeneral_vcp_templates_edittemplate.png
