Words and Expressions
The following are a number of common words and expressions used throughout the documentation:
Background scene: A background scene contains logic that enables an operator to toggle the states of multiple front scenes. A typical background scene also contains backplates and transition effects for each state of the front scenes. For example; A lower third may be on-air at the same time as a bug, and the lower third may be taken off-air without taking the bug off-air or reanimating it.
Component: In Viz Template Wizard, Components are used to create text fields, buttons, drop-lists, database connections etc.
Control Plug-ins: A graphics scene can contain all sorts of objects that can be controlled from a template such as text, back plates, images, colors and more. The graphics designer uses Control Plug-ins to expose objects to make them editable in a template. When importing the scene to Viz Template Wizard the exposed objects with control plug-ins appear as list items with check boxes.
Control Object: Every scene with control plug-ins must have one instance of the Control Object plug-in at the root level of a scene tree. Control Object reads the information from all other control plug-ins. When a scene is imported to Viz Template Wizard, it reads the information about other lower level control plug-ins through Control Object.
Data element: A data element is a template that is filled with data. A data element holds a reference to its template (original) just as the template holds a reference to its scene. A data element is contains a set of data and references to where data (e.g. images and video clips) can be found. In most cases it is the data element that gets played out on-air, and not the template.
Front scenes: A front scene is a standard scene that makes one part of a transition logic scene.
Newsroom Component: In a Newsroom Computer System (NCS), the Newsroom Component (NrC) is used to add data elements to a story. The user is typically a journalist working on a story. The NrC is an embedded application in the NCS that connects to a database of templates. The templates can be filled with text, images, video and maps.
Scene: A scene is built in Viz Artist. It can be a single scene, or a front scene controlled by a background scene (transition logic).
Template: A template is a customized interface created in Viz Template Wizard. The template is used in Viz Content Pilot or the Newsroom Component to create data elements that are added to a playlist for playout. A template is based on one or several (transition logic) Viz Artist scenes.
Transition Logic Scene: Consists of a background scene and one or several front scenes.
Viz Artist: The design tool where the graphics scenes and all animations are created.
Viz Engine: The output engine used for playout of graphics and video.
