Careful design of the styles you wish to use can greatly increase the speed at which high-quality maps can be created by a group of users. Users just need to select the correct style, and they can then create maps without having to be concerned with the design or appearance.
A number of sample style sheets are included with the software. You can import these as described below.
To Share a Stylesheet between Projects and Users
Once you have designed a style sheet that you would like to use in other projects, or make available to other users, you can save it to disk as follows:
Click the Export... button in the Styles Editor dialog box to save a copy of the style sheet in a shared directory.
Note: Each user can then import styles from the style sheet file using Import... in the Styles Editor.
