When launching the Map Builder, you are presented with the following options:
  • Navigator: Builds a scene with one starting point and up to 32 destinations.
  • Focus on Map: Creates a static scene with a base map only. Can only be used with flat geometries.
  • 1 Destination: Builds a scene with one starting point and one destination.
  • Map Object: Builds a scene with one starting point and one destination. The window option is used so that the map only uses part of the screen.
  • Open: Opens existing map template files.
