The Viz World Photoshop Plug-in is used to integrate Viz World and Adobe Photoshop files. Maps created with the Photoshop plug-in create a new file with separate layers for every feature and detail on the map.
The scripts which are installed as part of the plug-in are used to:
  • Configure the different settings of the Photoshop Plug-in.
  • Open Map Editor Classic to select the desired map.
  • Create the final Adobe Photoshop file and layers, based on the selection and configuration.
Installed Files
The Photoshop plug-in is installed under:
  • C:\Program Files\Adobe\Photoshop\Plug-ins\Import-Export or
  • C:\Program Files (x86)\Adobe\Photoshop\Plug-ins\Import-Export
The file that is installed is:
  • VizrtMapImport.8ba
The scripts are installed under:
  • C:\Program Files\Adobe\Photoshop\Presets\Scripts or
  • C:\Program Files (x86)\Adobe\Photoshop\Presets\Scripts
Important! Newer Versions of Adobe Photoshop (like CC 2017)  install in a different directory than C:\Program Files\Adobe\Photoshop. It might be required to copy the whole content of C:\Program Files\Adobe\Photoshop to the real Photoshop Installation location, usually at something like C:\Program Files\Adobe\Adobe Photoshop CC 2017.
To Install the Photoshop Plug-in
  1. Install Viz World Client (see Installing Viz World Client).
  2. Double click the VizWorld-Photoshop-xxx.msi.
Note: To support Adobe Photoshop 32-bit and 64-bit, there are two different installers, (x86 and x64). Ensure you have the installer which matches your Photoshop version, also a bundle installer is available for installing required dependencies, and provides the option to choose which Photoshop plug-in version to install (x86 and x64).
  1. Click Next.
To Configure the Photoshop Plug-in
  1. Launch Adobe Photoshop.
  2. Click File > Script > Viz World Setting.
  3. Enter the machine name of your Viz World Server.
Info: The configuration file used is located in C:\Program Files\vizrt\Maps\Photoshop if you need to edit the configuration manually.
