It is good practice to place all template (TPL) files in a single static location. The recommended location is:
  • 32-bit: C:\ProgramData\Curious Software\Curious World Maps\Users\Default\Projects
  • 64-bit: C:\ProgramData\vizrt\Viz World\Users\Default\Projects
This folder and any sub-folders are automatically scanned for TPL files when the Map Server is launched.
Note: The template location should be exactly the same on Viz World Server and any Viz World Classic design systems. If the paths are not identical, it may break the link to any image elements (for example, Markers).
To Open a Project Template
  1. Select Open... (CTRL + O) from the File menu.
  2. Select Project Template (*.tpl, *.tpt, *.cgt) from the Files of type drop-list.
  3. Select the template file and click Open.
To Save a Project Template
  1. Select Save (CTRL + S) from the File menu.
  2. Select Project Template (.tpl) from the Save as type drop-list.
  3. Enter a filename, and click Save.
