Vizrt iNEWS Command Plugin Admin Guide
Version 3.0 | Published September 08, 2017 ©
Known limitations for cg elements
Known Restrictions
Cannot Insert Data to Star CG Element Created Using Avid Command
In Avid Command the user can press ALT+ INSERT (or right-click the playlist and then select Insert > New item).
A pop-up window appears where the user can add a *cg element. Example:
Currently it is not supported that the user modifies editable fields for the new data item.
Video or Image in Graphics Element not Supported
If Viz One is configured for Viz Pilot in iNEWS, the user is not able to add such elements to the rundown using *cg syntax.
Default Template Values not Supported for Star CG Elements
If the user provides no data for a *cg syntax element (where the template has data fields), then the fields will be empty.
