STV_TextHighlight
graphics/scenedesign_stv_texthighlight_icon.png
Coloring text containing special characters
When STV_TextHighlight is placed on a text container, the plugin recognizes certain characters and lets you change the color of any word containing that character (for example: #tags @User http://).
Note: You must send text to the “text” property of this plugin using the ControlParameter.
An example Viz Artist scene is shown below:
graphics/scenedesign_stv_texthighlight_artist.png
The resulting scene, with important information highlighted, is as follows:
graphics/scenedesign_stv_texthighlight_result.png
Emoji
graphics/scenedesign_emoji.png
The Emoji option allows users to visualize emojis in a text. All emojis are a list of characters that are replaced by images.
graphics/scenedesign_emojiss.png
List of parameters:
Disable/Enable
Images: Default/Custom
When using default the plugin will use the images located under: C:\Program Files\Vizrt\Viz3\plugin\data\TextHighlight\72x72
When using custom the user can define a path to their own images (Note that the custom path should be accessible to all machines running VizEngine, including Trio and Preview engines.)
Word Folder: allows the user to define a folder of images containing words that should be replaced by emojis
Ignore List: allows the user to define a list of characters that should be ignored when replacing with emojis
Word List Separator: character to be used as a separator of the list of words to replace by emoji
Word List: list of words to be replaced by emojis
TextFX
graphics/scenedesign_textfxss.png
The Text FX option allows users to apply similar effects as Text FX plugins when using emojis. For more information please refer to section ‘TextFX’ in the Viz Artist User’s Guide.
