The database parameters (also called VCP parameters) are stored in the Pilot database and served by Pilot Data Server to every connected client. You edit them from the Parameters panel in DataServerConfig.
Caution: These settings apply to every client connected to this Pilot Data Server and should only be changed by administrators. Some changes require a server restart before they take effect.
The parameters are grouped below by relevance:
Settings used by Pilot Edge and Template Builder – the settings you configure for a modern system.
Newsroom and system settings – newsroom (MOS) integration and system-level settings such as on-air updates and spell checking.
Legacy settings – kept for backwards compatibility but not used by Pilot Edge or Template Builder.
Settings managed internally by Pilot Data Server – the server reads or maintains these; do not change them unless instructed.
These are the parameters that affect a modern Pilot Edge / Template Builder deployment. Several of the Pilot Edge UI toggles are more conveniently set from the Pilot Edge panel in Data Server Config, but are listed here for completeness.
Parameter | Description |
| Host or reverse-proxy URL of the Graphic Hub REST API used to provide scenes (for example |
| Base URL of the Preview Server used to render preview images in the editor (for example |
| URL of the image Crop Service used when cropping images in templates and data elements (for example |
| Viz World (maps) server IP or host name. In a multi-server setup, use a comma-separated list of IPs/host names. |
| Settings for the Viz Maps service used by the map editors in Pilot Edge and Template Builder. Set from the Viz Maps section of the Pilot Edge panel. See Viz Maps. |
| URL of the Viz Arc MOS plug-in panel. When set, the Viz Arc actions tab is shown in Pilot Edge. |
| Qualifier string that identifies the Viz Arc MOS editor when reopening Viz Arc items from the newsroom system. Default |
| Title of the Viz Arc tab in Pilot Edge. Default Viz Arc. |
| URL of the Mosart MOS plug-in panel. When set, the Mosart tab is shown in Pilot Edge. |
| Qualifier string that identifies the Mosart MOS editor when reopening Mosart items from the newsroom system. Default |
| Title of the Mosart tab in Pilot Edge. Default Mosart. |
| If true, the Images tab is hidden in the Pilot Edge top bar. Also configurable from the Pilot Edge panel. |
| If true, the Videos tab is hidden in the Pilot Edge top bar. Also configurable from the Pilot Edge panel. |
| If true, uploading and pasting images into image fields is disabled in Pilot Edge. Also configurable from the Pilot Edge panel. |
| If true, the template and element browser default to list view without thumbnails. Also configurable from the Pilot Edge panel. |
| If true, users cannot overwrite existing data elements when saving (only Save As is available). Also configurable from the Pilot Edge panel. |
| If true, users may delete data elements from the Pilot Edge element browser. Also configurable from the Pilot Edge panel. |
| JSON value holding default Pilot Edge UI settings under the |
| JSON value holding per-profile settings (default concept, available concepts and tags) used by Pilot Edge. Managed from the Template Builder profile editor. |
| JSON value holding the Mosart timing configuration. Each group can set a Default Duration ( |
| URL template used to open the Viz One order-management form for image/asset orders. |
| Default language used for spell checking (for example |
| URL that serves the dictionary files used for spell checking. Replaces the legacy |
| Name of the default style for template forms in Pilot Edge and Template Builder. Empty uses the built-in style. Set from the Template Builder Style Editor or the Pilot Edge panel; the |
These settings configure newsroom (MOS) integration and system-level behavior. They are relevant to a modern deployment but are set less often than the core settings above.
| Overrides the MOSID used in the MOS items produced for the newsroom system. Default |
| Public URL of this Pilot Data Server, or of the reverse proxy in front of it (for example |
| URL of the Pilot MOS HTML plug-in that Trio/Director uses to open elements and templates that do not have a proper legacy form. Must point at the final (non-redirecting) Pilot Edge URL – for example |
| Poll interval, in seconds, for update scripts. When Update at regular intervals while on air is enabled for a template, the Media Sequencer invokes the update service using this interval. Minimum 2 seconds; default 5. |
| Channel video mode, |
Legacy settings (not used by Pilot Edge or Template Builder)
These parameters are used by the legacy ActiveX Newsroom Component (Viz Pilot News / Director), the legacy Template Wizard, or Viz Object Store. They are kept for backwards compatibility and have no effect in a Pilot Edge / Template Builder system.
| Timeout, in milliseconds, waiting for the Viz Preview Engine connection before continuing. Default 10000. |
| Used by the legacy client to decide whether sub-fields can be added to custom layouts. |
| Default for showing/hiding the Graphic Event Timing options in the newsroom component when saving an element. Could be overridden per template in Template Wizard. |
| Disables clearing all layers as the first commands sent when sending to preview. |
| Disables drag-and-drop in the newsroom component (for newsroom systems that do not support it). |
| Disables dragging media from search results to the rundown. |
| Disables saving of overlay timelines for clip assets that have an |
| Shows the refresh button in the ActiveX external preview form. |
| Enables the Add to Rundown option in media search (for newsroom systems without drag-and-drop). |
| Forces a detached snapshot-preview window in the ActiveX/VCP client. |
| Hides the data element list in the legacy newsroom component. Pilot Edge does not read this database parameter; the equivalent behavior is controlled by the |
| Hides the media tab in the newsroom component. |
| Adds a |
| Controls whether the ActiveX returns to the template list after saving (when editing). |
| Host name of the Viz Engine used by the legacy client to generate snapshot previews and fetch resource icons. |
| Requests snapshots in different image formats. |
| Port of the Viz Engine used by the legacy client for snapshot previews and resource icons. |
| Sends values to the legacy transition-logic location ( |
| Uses the |
| Disables sending |
| Removes |
| Minimum required version of the Vizrt newsroom component; a warning is shown if the client is older. |
| Changes Save As New behavior so the original item in the script is not replaced. |
| Turns tooltips in the ActiveX on/off (tooltips could crash the Dalet newsroom system). |
| Asks users whether to save the open element or template when opening another. |
| Embeds the Viz Curious Maps Editor inside the newsroom component window. |
| Default channel for video clips, written to the |
| Language used for the legacy country list. English is supported by default. |
| Password protecting data-element deletion in the legacy client. Empty means no password. |
| Disables the built-in Viz Object Store search (used when moving to RESTful VOS search). |
| Placeholder URL template for image orders. |
| Path the legacy image Crop Tool uses when saving a cropped image (UNC or Windows path). |
| Number of media-search items per page in the legacy client. |
| Overrides the (legacy VBScript) script runner used by the Media Sequencer. Superseded by the modern Update Service. |
| URL of the legacy VBScript script runner that executed update scripts. Superseded by the modern Update Service. |
| Shows an index column in the legacy VCP playlist. |
| Reduces the client-generated MOS XML by removing optional tags. |
| Dictionary/affix file base name for the legacy spell checker (default |
| Path to the legacy spell-checker dictionary files. Superseded by |
| Service-document URL for the legacy Timeline Update Service. |
| Encrypted Viz Object Store password. Set it through the VOS change-password dialog, not here. |
| Enables/disables the Object Store toolbar for editing images and person information ( |
| Allows saving templates with the same name in different concepts in the legacy Template Wizard. |
Pilot Data Server reads or maintains these parameters itself. Do not change them unless a Vizrt representative instructs you to.
| Legacy |
| Major version of the database schema. Read by the server on startup. Do not modify. |
| Minor build version of the database schema. Do not modify. |
| Database schema name (for example |
| Internal schema/version compatibility marker. Do not modify. |
| URL template the server uses to build the model-document link for a template. Used by the Maps Preview Server and certain external systems. Do not change. |
| URL template the server uses to build the payload-document link for a data element. Used by certain external systems. Do not change. |
| Maximum area (width × height, in pixels) of a cropped image served by the server; larger images are resized while keeping the crop aspect ratio. |
| When enabled, the server adds the element's default channel ( |
| When enabled, the server adds the element's stored page data to the MOS item (used by some Mosart integrations). |
| Overrides the |
| Overrides the |
| Overrides the |
