The STV_HTTP Recognizer plug-in recognizes a HTTP link in text geometry when placed on a text container.
In some cases, messages coming from social media networks such as Twitter or Facebook contain links to other sites. This plug-in hides the link from the message as these links provide no meaningful information for broadcasts.
The plug-in can additionally store the value of this HTTP link in a DataPool or shared memory variable.
Note: This plug-in is located in: Plugins -> Container plug-ins -> SocialTV
HTTP Recognizer Properties
- Work On Text Changes:
- Hide Links: Specifies whether or not discovered links are to be hidden.
- Target: - DataPool:
- Shared Memory:
- Variable: Sets the name of the variable in which the URLs of discovered links are to be stored.
- >Use Object Container: Allows one container to affect another container, or allows another instance of the same plug-in to be used on the same container. DataPool container plug-ins affect the containers they are attached to, and cannot affect other containers directly. When enabled, additional options are also enabled: - Which: - PARENT: The DataPool plug-in affects the parent container (i.e. the container residing above the current container in the scene hierarchy).
- GrParent: The DataPool plug-in affects the grandparent container (i.e. the container residing two levels above the current container in the scene hierarchy).
- GrGrParent: The DataPool plug-in affects the great grandparent container (i.e. the container residing three levels above the current container in the scene hierarchy).
- REMOTE: When remote is selected another parameter, Remote Container, is enabled. Drag the container to be effected to the container place holder.
- Shared Memory Variable Type: Selects the shared memory area to update. Can be either Global, Scene or Distributed.
- Apply:
- Init:
