Location: Plugins → Container Plug-ins → Text Compatibility: V3 Classic, V4 PBR Category: Text
Note: This plugin is inactive by default and should only be used for compatibility reasons
Overview
The Format Number plug-in formats a numeric or date string displayed in a Text geometry container. It takes the raw text value, parses it as a number or date, and rewrites the text with the chosen formatting (including decimal places, thousand separators, currency symbols, percentage notation, and date layouts).
Negative values can optionally be displayed in a user-defined color for visual emphasis (for example, red for losses in financial graphics).
Format Modes
The plug-in provides four formatting modes, selectable via the Format parameter:
Mode
Description
Example
Number
Plain numeric formatting with configurable decimal places, fraction types, and thousand separators.
1234.5 → 1,234.50
Percentage
Multiplies the value by 100 and appends %. Uses the same numeric formatting options.
0.75 → 75%
Currency
Prepends or appends a currency symbol with configurable negative notation.
-1234 → (EUR 1,234)
Date
Parses a date string and reassembles it using the chosen field order, separators, month/year/day styles, and optional weekday.
07.03.2025 → March 7, 2025
Parameters
General
Parameter
Default
Description
Text
empty
The input text to format. Typically bound to the container's text content.
Format
None
Formatting mode: None, Number, Percentage, Currency, Date.
Number / Percentage / Currency Options
Parameter
Default
Description
Negative numbers
-123
Display style for negative values: -123 or (123).
Negative currency
-EUR 123
Negative notation in Currency mode: -EUR 123, EUR -123, (EUR 123), or EUR (123).
Negative Color
White
Per-character color applied when the value is negative.
Fraction Type
Decimal
Decimal display or fractional notation: Decimal, 1/2, 2/4, 4/8, 8/16, 5/10, 50/100.
Decimal places
0
Number of decimal digits (0–6). Only visible in Decimal fraction type.
Decimal separator
Point
Character for the decimal point: . or ,.
Replace Zero
Off
When enabled, replaces zero values with a custom string.
Replace Zero by
The replacement string used when the value is zero.
Use Thousand separator
Off
Enable thousand grouping (e.g., 1,234,567).
Thousand separator
Comma
Character for thousand grouping: . or ,.
Currency
EUR
The currency symbol or text. Only visible in Currency mode.
Date Options
Parameter
Default
Description
Date Input
European
Input parsing order: European (dd.mm.yyyy) or American (mm/dd/yyyy).
Date
DD/MM
Output field arrangement: DD/MM, MM/DD, DD/MM/YY, MM/DD/YY, MM/YY, YY/MM, or User (custom format string).
Format
WW the DD on MM year YY
Custom format string (User mode). Tokens: W = weekday, D = day, M = month, Y = year.
Year
2009
Short (09) or full (2009) year.
Month
03
Month display: 03, 3, Mar, March, or M.
Day
07
Day display: zero-padded (07) or plain (7).
Day In Week
None
Optional weekday prefix: None, long (Tuesday), or short (Tue).
Month Separator
Separator between month and year: /, -, ,, ., or space.
Day Separator
Separator between day and month.
Week Day Separator
Separator after the weekday name.
Usage Example
Formatting election results
  1. Create a Text geometry container with the raw value (for example, 12345.678).
  2. Add the Format Number plug-in to the container's function stack.
  3. Set Format to Number.
  4. Set Decimal places to 1, enable Use Thousand separator.
  5. Result: 12,345.7.
Currency display with negative coloring
  1. Set Format to Currency, Currency to $.
  2. Set Negative currency to ($ 123).
  3. Set Negative Color to red.
  4. Input -500 → displays as ($ 500) in red.
Technical Notes
  • The plug-in writes directly to the Text geometry on the same container. It overwrites the displayed text each frame when the input changes.
  • Parameters that are not relevant to the current format mode are automatically hidden in the GUI (for example, date options are hidden in Number mode).
  • Fractional display modes (½, ¼, etc.) use Unicode fraction characters when available.
