What it is. GeoCamera is how you point at the world. Rather than positioning a camera in 3D space and working out where that lands on the map, you say it directly: this place, this close, turned this way, tilted this much. It is what makes "fly from Berlin to Cairo" a matter of two coordinates and a zoom instead of a hand-keyframed camera move, and every map animation is built on it. It drives the view, and anything anchored to the map moves with it.
It lives on the same container as the GeoCanvas and is added automatically by Viz Artist.
The four you will actually touch are Latitude, Longitude, Zoom and Bearing. The rest are set once and left alone.
See chapter Working with Maps for detailed information
Parameters
Parameter | What it is for |
Latitude / Longitude | The point on Earth at the centre of frame. This is your "where" — animate these two and the map travels. Latitude also quietly changes how much ground a zoom level covers, which is why the same zoom feels much closer in Norway than in Kenya. |
Zoom | How close you are. Each whole step doubles the scale: zoom 4 is a continent, 10 a city, 16 a few streets, 20 a building. Fractional values are fine and are what make a smooth push-in possible. |
Bearing | Which way is up, in degrees. 0 is north-up. Rotate it to follow a route, to line a coastline up with your lower third, or simply because the story reads better at an angle. |
Pitch | How far the camera tilts from looking straight down. 0 is a flat overhead map; increase it and the view leans into perspective, with the horizon appearing at high values. This is what turns a map into a landscape shot. |
Projection | How the round Earth is flattened. Mercator is the familiar web-map look — shapes stay true locally, but areas stretch badly toward the poles (the reason Greenland looks continental). Equirectangular keeps latitude and longitude on an even grid, which suits full-world graphics where the polar distortion of Mercator would be distracting. Pick one at design time; it is not something to animate. |
Resolution | The frame size the camera reckons against, in pixels. Worth understanding rather than ignoring: zoom is defined relative to this, so the same zoom on a different resolution shows a different amount of ground. Keep it matched to your output format unless you have a specific reason not to. |
View bounds | Read-only. The rectangle of the world currently in frame, as west/south/east/north. Useful for checking what is actually visible — whether the region you care about is fully in shot before you commit to a zoom. |
