The Plug-ins User Guide provides details about settings available through its configuration user interface within Viz Artist or Viz Engine.
Note: The Viz World plug-in package is released separately from the Viz World Client. Some of the functionality of these plug-ins are still intended to be used with the Viz World Client.
Plug-in Color Coding
Plug-ins have different label colors for easier and faster work.
Icon | Plug-in | Style |
Geometry plug-ins | Blue label | |
Container plug-ins | Gray label | |
DataPool plug-ins | Gray label with blue triangle | |
Control plug-ins | Gray label with green triangle | |
Scene plug-ins | Pink label | |
Shader plug-ins | Green label | |
Viz Engine Shader plug-ins | Purple label | |
Media Asset plug-ins | Black label |
Supported Pipelines
If a Plug-in is not supported in both Viz Engine Renderer and Classic Renderer, the Supported Pipelines section shows which render pipeline is supported:
Supported Pipelines | |
Classic Render Pipeline |
Viz Engine Render Pipeline |
Related Documents
Viz Artist User Guide: Contains information on how to install Viz Engine and create graphics scenes in Viz Artist.
Viz Engine Administrator Guide: Contains information on how to install the Viz Engine software and supported hardware.
Viz Ticker User Guide: How to install, configure and use the Viz Ticker client, and configure the output channels.
Viz Trio User Guide: How to install, configure and use the Viz Trio client, and configure the output channels.
Viz Pilot User Guide: How to install, configure and use Viz Pilot.
Viz Multichannel User Guide: How to install, configure and use Viz Multichannel.
Viz World Classic User Guide: Contains information on creating 2D maps and geographic animations.
Viz World User Guide: Contains information on creating real-time 3D maps and using the client-server solution.
For more information about all of the Vizrt products, visit:
Feedback and Suggestions
Legal
Copyright ©2026 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Real-Time Scanning: Keep it enabled, but exclude any performance-sensitive operations involving Vizrt-specific folders, files, and processes. For example:
C:\Program Files\[Product Name]
C:\ProgramData\[Product Name]
Any custom directory where [Product Name] stores data, and any specific process related to [Product Name].
Risk Acknowledgment: Excluding certain folders/processes may improve performance, but also create an attack vector.
Scan Scheduling: Run full system scans during off-peak hours.
False Positives: If behavior-based detection flags a false positive, mark that executable as a trusted application.
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at http://www.vizrt.com .
Support
