Vertex Skin is the main plug-in that marks a mesh that uses Vertex Skinning.
Note: Do not remove this plug-in as this would need a clean, new import (not re-import) to get the scene running again.
Vertex Skin Parameters
Root: Defines the container under which Vertex Skin finds the bones to use.
Show bones: Verifies the location of each bone visually.
Show the weight of a bone: Visualizes the influence of the selected bone container on the target mesh. Only usable with no other Shader present.
Ignore transform on mesh container: Can be deactivated to incorporate the transformation of the mesh container.
Note: Deactivating is strongly discouraged.
Shared Memory Tracking: Uses data from shared memory to update the transformations of bones.
Shared Mem. Key: Defines the shared memory key name that receives the data field value.
Bone Key Prefix: Defines a prefix that is added to Vertex Bones.
Position Root Bone only: Positions the Root Bone without positioning the other bones.
Motion Capture Live Tracking
To apply live motion capturing data to a Viz geometry, the following steps are required:
Setup Viz Tracking Hub for Motion Analysis Motion Capturing (See the Motion Analysis Integration page in the Appendices section of the Tracking Hub User Guide).
Note: Requires Tracking Hub 1.1.2. or newer
Load motion capture data in Motion Analysis Cortex control application.
Run Viz Artist with activated Tracking Hub usage.
Load the imported mesh and navigate to the first Vertex Skin plug-in instance in your scene.
Activate Shared Mem Tracking with the key name set in Cortex. You should see all available tracking bones in the Vertex Skin plug-in's textbox below. This indicates that the information flows correctly from Cortex to Tracking Hub to the Viz Engine.
Due to accuracy issues of the motion capture system, it could make sense to activate Position Root Bone only. This translates only the root bone and all related child bones are rotated.
