Reality Connect requires camera data to function properly. This implies a few changes to the regular Tracking Hub configuration. For this guide, let us assume the following configuration.
Copy Rig
Copy the last rig in the chain, connected to the camera service, which is usually the Lensfile.
Add Camera Service
Add a second camera service.
Connect the second camera service with the previously created copy of the rig.
Specify the following values:
  • IP: IP of the machine where Reality Connect is running.
  • Tracking Port: Choose a free port other than for the first camera service. Reuse this port for the Tool Configuration.
  • Command Port: Same value as for the first camera service.
Delay Configuration
Both camera rigs contain a field Overall Delay (Fields). This allows to specify different delays for sending the camera tracking data to Viz Engine and Reality Connect. Follow the instructions in Delay Configuration to configure the optimal delays.
