Channel Recorder supports the following sets of Multiport Video Computer Protocol (MVCP) commands:
Supported Global MVCP Commands
Command | Function |
| Closes the current connection. |
| Initiates event monitoring mode. |
| Returns the supported media ports. |
| Creates a new unit. |
| Returns the existing VST units. |
Supported Unit MVCP Commands
| Gets the current status of the VST Clip Cache (the numbers displayed are bytes used/available). |
| Cues recording of the unit’s currently loaded clip. |
| Loads a clip into a unit. |
| Sets controls for the unit: |
| Stops playback or recording. |
| Closes a unit. |
| Unloads the unit’s currently loaded clip. |
| Returns the status of a unit. |
Example MVCP Commands Sent by Viz Dart
UADD CS_ENCODER1 * SHAR dartDISC global U1UERR U1SET U1 MED vtr.media.clip.format "movie/stream/mxf"SET U1 MED vtr.media.video.input.compression.type "mpeg2-ibp-422p@hl"SET U1 MED vtr.media.audio.input.channels 4SET U1 MED vtr.media.audio.input.sample.width 16LOAD U1 LUTAS_-_GLORY_62_-_SPORTV.mxf IN CRTE NOEXSET U1 MED vtr.media.clip.start.mode "time-of-day"SET U1 MED vtr.media.input.trigger.duration.out "04:00:00:00"CUER U1@14:50:00:00 REC U1USTA U1UCLS U1UNLD U1
The Video Server Toolkit Developer’s Guide on ftp.sgi.com (alternate link).
