Template Builder lets you make customized templates using scene import or existing templates from Viz Pilot's Template Wizard. This user guide shows you how to customize templates.
Info: A key feature is that you can add custom HTML panels to templates, giving full control over the template through custom scripting and logic.
Workflow
A simplified version of the workflow follows below:
  • Scenes are made in Viz Artist.
  • The scenes are imported into Template Wizard, where templates are made.
  • Templates are edited and new templates can be made in Template Builder.
  • The template is saved in the Viz Pilot system and is available to newsroom and control room systems for playout.
Note: Changes made to a template in Template Builder are not be available when opening the template in Template Wizard.
Feedback and Suggestions
Support
Copyright ©2026 Vizrt. All rights reserved.
Disclaimer
Antivirus Considerations
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at http://www.vizrt.com .
Support
