In Template Builder there are some built-in system environment variables, and it is also possible to define your own environment variables through URL parameters to the application, or specifying these in optional settings in DataServerConfig. If defined by URL parameters, these must also be added to the Viz Pilot Edge URL when templates and data elements are using these variables. If a variable is used, but not defined, it is possible to set a default value.
Defining Environment Variables
The application defines the following application specific environment variables:
Variable
Value
$APP
"TemplateBuilder" or "PilotEdge".
$PDS
The base URL of Pilot Data Server that the application is connected to.
$GH
URL to the configured Graphic Hub for scenes.
URL Parameters
It is possible to define custom environment variables to be used in the templates. These variables can be specified as URL parameters to the application. Environment variable in the URL must use the format $var=value, where the name of the variable must start with a dollar sign and the value is set after the equal sign. There can be multiple environment values specified. For example, if the variable version can be specified like this in the URL to the application http://mypds:8177/app/templatebuilder/templatebuilder.html?$version=v1, then the value of the variable version can be used when specifying URLs to HTML panels, in feed URLs, expressions and auto title formatting.
Info: This is an example of how to define a variable called version in your URL: http://mypds:8177/app/templatebuilder/templatebuilder.html?$version=v1.
Optional Setting in DataServerConfig
Custom environment variables can also be configured in DataServerConfig, by adding optional settings fields with names prefixed by env-. For example, a setting named env-myserver with value https://api.example.com is available as the environment variable myserver (usable in URL placeholders as {$myserver}). These are handy for configuring spell checker dictionary base path and language.
Style Variable
The style variable holds the name of the default style for template forms, see Styling. It is stored in the env-style database parameter, which is set from the Style Editor or from the Pilot Edge settings in DataServerConfig. The $style URL parameter overrides it, for example ?$style=Studio%20Dark.
Using Environment Variables
In general, the notation for using environment variables is {$var|default}, where var is the name of the variable and default is the default value if the variable is not defined.
When using an environment variable in a URL, the URL must be prepended with "{$}" if it does not start with an environment variable.
See the examples below:
Scenario
Example
Description
URL to HTML panel or full HTML page
{$} http://mywebserver/templatepanels/{$version|v1}/mypanel.html
The full URL used by the application is http://mywebserver/templatepanels/v1/mypanel.html if the environment variable version is not defined in a URL parameter.
URL to a feed of objects from graphic hub
{$GH} /files/BAA340C1-C71E-0949-BCF6-F7E043856030/
The {$GH} environment variable contains the full URL to the Graphic Hub and certifies that if the system is configured to point to another Graphic Hub, the link still works.
Inside HTML fragments
<img src="{{$PDS}}/pilotedge-3.0/vizPilotEdgeLogo.svg">
Note the double brackets around the variable.
{{$APP}} <br>
{{$PDS}} <br>
{{$GH}}
Writes out the application specific environment variables.
Auto generated title format
{field1} / {field2} ({$version|DEV})
Concatenates the values of field1 and field 2 and the word DEV, if version is not defined in a URL parameter.
In expressions
{{$APP}}==="TemplateBuilder"
Note the double brackets. This can hide a field if the template is opened in Template Builder, when added to the "Hidden expression" for a field in the field editor.
In scripting
const value = vizrt.$env["headline"]
Example URL: http://pds-host/pilotedge.html/?%24headline=Spurs+wins+Premier+League&template=25480
// Minimal scripting example. This code will open a template in Pilot Edge and fill the
// headline field from the "headline" environment variable in a URL like
// http://pds-host/pilotedge.html/?$headline=Spurs+wins+Premier+League&template=25480
vizrt.onCreate = () => {
fillHeadline()
function fillHeadline (): void {
if (value !== undefined) {
vizrt.fields.$headline.value = createRichText(value)
} else {
console.log("No value set for headline");
