This page lists available keyboard shortcuts in Template Builder.
Shortcut | Description |
CTRL + O | Open the Open Template dialog where you can select a template to open. |
CTRL + S | Save a template. |
CTRL + Z | Undo. |
CTRL + Y | Redo. |
F5 | Run or stop the template script in Design mode. |
ALT + R | Switch between Run mode (Run Template) and Design mode (Back to Design). |
ESC | Leave Run mode (Back to Design). |
CTRL + C / CTRL + V | Copy and paste the selected fields and UI items of a custom tab, in layout edit mode. |
Warning: The shortcut CTRL + O does not work properly in Firefox version 65.0.1 and later.
Graphics Preview Player Shortcuts
Use the following shortcuts for the Graphics Preview player:
SPACE or CTRL + SPACE | Play/pause. |
SHIFT + I | Go to the in-point. |
SHIFT + O | Go to the out-point. |
, (comma) | Move one frame back. |
. (period) | Move one frame forward. |
