Log Files
The Viz Virtual Studio log files are located in
C:\ProgramData\vizrt\VizTH, and consist of the following files:
Tracking Hub Console Log File:
VizTH.log
Tracking Log Files:
VizTH_rcvX.logwhereXis a number. The files can for example beVizTH_rcv1.log,VizTH_rcv2.log, etc. -
VizTH_sendX.logwhereXis a number. The files can for example beVizTH_send1.log,VizTH_send2.log, etc.
Timing Log File:
VizTH_timingX.logwhereXis a number. The files can for example beVizTH_timing1.log,VizTH_timing2.log, etc.)
The increment of the number (X) is when the first file reaches a size of 1 MB. All log files change to the next number at the same time.
Exception Log Files:
In the event of an unrecoverable exception error, the information provided in the user interface dialogue box are automatically saved to a log file using date and time as filename, for example
2016_04_20_16_30_30.log.
