Convert Case
Converts ASCII strings to upper or lower case. Current container must hold a string.
The default path for this plugin is C:\Program Files\vizrt\Viz3\plugin\ConvertCase.vip.
Properties and Parameters
  • Upper/Lower: Converts the text for the specific container to upper or lower case.
FUNCTION*ConvertCase*text_case - int; 0: upper, 1: lower
FUNCTION*ConvertCase*text - string
To convert a string to upper or lower case
  1. Add a group to the scene tree, and add a font to it.
  2. Add the Convert Case plug-in to the same container.
  3. Open the Convert Case editor, and enter text in the editor.
  4. Click the Upper button to convert to upper case text, or click the Lower button to convert to lower case text.
