Mark Text
The Mark Text plug-in allows you to underline words in a text string with a.
The default path for this plugin is C:\Program Files\vizrt\Viz3\plugin\markText.vip.
Properties and Parameters
  • Text to Mark: Sets the text that should be marked. Note that the text is case sensitive.
  • Select: Selects where the underline should be placed. Available options are foreground (Fg), background (Bg), Both and None. Background will underline the text's shadow.
To mark text
  1. Add a group container to the scene tree and name it Text.
  2. Add a font to the Text container.
  3. Open the font editor and enter a text string.
  4. Add the Mark Text plug-in to the Text container.
  5. Open the Mark Text editor and enter a word from your text string.
Note: Do not change the font type between texture and geometry as this will not affect the whole string when using the Mark Text plug-in.
