Text FX Rotate
The Text FX Rotate plug-in allows you to create an effect where the characters rotate on the X-, Y- or Z-axis.
The default path for this plugin is C:\Program Files\vizrt\Viz3\plugin\TextFxRotate.vip
Properties and Parameters
Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
Use Axis: Defines on which axis the characters rotate.
Begin: Sets the initial rotated position of the characters.
End: Sets the ending rotated position of the characters.
Common Text FX Properties and Parameters.
