Version 3.9.0 | Published December 13, 2017 ©
GeoGraffiti
images/download/attachments/27789524/viz_icons_geograffiti.png
The Graffiti Texture plug-in gives the ability to draw freehand on top of containers with the Globe plug-in. The freehand draw is created with a brush shape, used with a mouse. The plug-in can also recognize some rendered shapes, such as circles, ellipses, crosses, and arrows, and replaces the hand-drawn item with the recognized shape.
The plug-in can either work in combination with Viz Engine’s multi-texturing technology or can add a standalone texture.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> Texture
GeoGraffiti Properties
images/download/attachments/27789524/plugins_container_geograffiti_properties_color.png
  • Active: Enable/disable drawing
  • Texture Width: Dimensions of the texture used for drawing canvas
  • Brush Type: Color or eraser brush
  • Brush Image: Optional image that will determine the shape of the brush. If empty, a round brush will be used
  • Brush Width: Width of the brush in pixels. Visible only if the selected Brush Type is Color
  • Eraser Brush Width: Width of the eraser in pixels. Visible only if the selected Brush Type is Eraser
  • Brush Color: Color of the brush
  • Recognize Shapes: Shape recognition mode (on/off)
    • Recognize Ellipse: Specifies whether shape recognition will try to recognize ellipse shape
    • Recognize Circle: Specifies whether shape recognition will try to recognize circle shape
    • Recognize Cross: Specifies whether shape recognition will try to recognize cross shape
    • Shape Delay: Number of frames to wait from mouse up before trying to recognize shapes
    • Draw Arrow: Specifies whether non-recognizable shapes will be converted to an arrow
    • Arrow Length: Set the length of an arrow head
    • Arrow Width: Set the width of an arrow head
    • Circle Rad: Radius of the circle replacing a recognized circle. If zero, the radius of the recognized circle will be used
    • Cross Width: Width of the cross replacing the recognized cross shape. If zero, the width of the recognized cross shape will be used
  • Enable Undo After Clear: Enable undo after the Clear button has been used.
  • Clear (button): Clears the canvas
  • Undo (button): Undo
  • Redo (button): Redo
