Version 3.9.0 | Published December 13, 2017 ©
Look-At
images/download/attachments/27789346/viz_icons_look_at.png
The Look-At plug-in is used to rotate a Container so that it faces a defined direction. This is especially valuable in animations.
This section also contains information on the following topic:
Look-At Properties
images/download/attachments/27789346/plugins_container_cflookat.png
  • Auto Rotation
    • None: No rotation
    • Billboard: Will rotate the container to face the camera
    • Follow Path: Will rotate the container to justify at the animation path
  • Keep Size:
  • Billboard Axis: Only with Billboard:
    • X: The container will rotate about its X-axis to face the camera, even if camera moves
    • Y: The container will rotate about its Y-axis to face the camera, even if camera moves
    • XY Camera: The container will rotate about its X- and Y-axis to face the camera, even if it moves
    • XY Screen: The container will rotate about its X and Y-axis to face the camera if the camera orbits the container only
